31 minutes ago, robworld said:
You are right! but if this works with an analog manual lens from the 70s without AF electric, I guess it should work with an M lens, too.
The reason why it works must be the chip, not the adapter, I guess
I wish it worked as i would be tempted to order a Kolari modded A73 to upgrade my A7s mod then.
On 12/4/2019 at 1:20 AM, lct said:
Would you mind to elaborate? I must click twice on my A7s1 with whatever adapter.
From Gary Friedman's A7III Guide:-
To assign a function to a button, just do the following:
For Stills: MENU - 2 - 8 - (Image) Custom Key - [Choose a button] - [Choose a function to assign to that button].
Leica C image of the relevant screen.
Thank you Keith but if you assign it to a button, are you sure you don't have to press twice on it? On my A7s mod, i use the C1 button for focus magnification and i have to click twice on it. First click to trigger the focus patch and second click to display the magnified view. Does your A73 work differently?
Edited by lct
  • 3 months later...
@lct:
if you set the "Initial Focus Magnification" in the menu to 5.6 instead to 1 then one click will be enough.
This works on the A7III, maybe on the A7s too.
If "AF in Focus Mag." is set to "Off" then the magnification will be reset with the shutter release button.
Edited by TeeGee
