g2van Posted November 13, 2019 Share #1 Posted November 13, 2019 Advertisement (gone after registration) Would really appreciate some help here. Today I attached the 11-23mm on my CL and it won't fire the shutter. Here are the symptoms: 1) when powered on, the battery bar on the top screen blinks 4 times (on other T lenses that are recognised, this doesn't happen) 2) Aperture priority mode - can't chose aperture (shutter priority is fine) 3) Touch AF on LCD screen doesn't work 4) Lens Profiles is "Off" even when I select "Auto" 5) Optical Image Stabilization is "On" 6) In "Camera Information" menu, "Lens firmware version" is disabled 7) Tried wiping the contact points. No difference. My other T lenses all work just fine. I never dropped this lens, just put it away for a few weeks. Last time I used, all was good. Confused. Please help! Quote Link to post Share on other sites More sharing options...
Advertisement Posted November 13, 2019 Posted November 13, 2019 Hi g2van, Take a look here Help! CL not recognising 11-23mm. I'm sure you'll find what you were looking for!
wda Posted November 13, 2019 Share #2 Posted November 13, 2019 Have you tried cleaning the contacts? Quote Link to post Share on other sites More sharing options...
g2van Posted November 13, 2019 Author Share #3 Posted November 13, 2019 yes cleaned contacts twice. no difference Quote Link to post Share on other sites More sharing options...
jaapv Posted November 13, 2019 Share #4 Posted November 13, 2019 Sounds like a firmware mismatch. Quote Link to post Share on other sites More sharing options...
NigelG Posted November 13, 2019 Share #5 Posted November 13, 2019 I vaguely remember some kind of firmware issue with this lens on my TL2 or T (can’t remember which) after lens/body firmware updates - I think I had to “force” an update onto the lens as there was an error of some sort. I think what solved it was taking the battery out of the body for a while then reinserting it with the lens already attached to the body. When it started up it updated the lens which had not happened when I just attached the lens in the normal way. Not sure if this would work here or not....but maybe? 1 Quote Link to post Share on other sites More sharing options...
g2van Posted November 13, 2019 Author Share #6 Posted November 13, 2019 2 hours ago, jaapv said: Sounds like a firmware mismatch. How can I resolve this? I can't find any firmware for the 11-23mm. Quote Link to post Share on other sites More sharing options...
jaapv Posted November 13, 2019 Share #7 Posted November 13, 2019 Advertisement (gone after registration) 26 minutes ago, g2van said: How can I resolve this? I can't find any firmware for the 11-23mm. Lenses are not user-updatable. The camera takes care of it. Check if your camera is on the latest software. If not, update and see if it solves the problem. If that doesn‘t work, mount your lens on another CL (Leica dealer) and see if it works. If the problem still persists, send camera and lens to Leica. Quote Link to post Share on other sites More sharing options...
g2van Posted November 13, 2019 Author Share #8 Posted November 13, 2019 8 minutes ago, jaapv said: Lenses are not user-updatable. The camera takes care of it. Check if your camera is on the latest software. If not, update and see if it solves the problem. If that doesn‘t work, mount your lens on another CL (Leica dealer) and see if it works. If the problem still persists, send camera and lens to Leica. Ah, thanks. I have the latest firmware 3.1 so I will try your other suggestion - thanks! Quote Link to post Share on other sites More sharing options...
