tommonego@gmail.com Posted November 5, 2019 Share #1 Posted November 5, 2019 Advertisement (gone after registration) Is there any problem using a DR Summicron on an M8? Is close focus mode still operational? Link to post Share on other sites More sharing options...
Advertisement Posted November 5, 2019 Posted November 5, 2019 Hi tommonego@gmail.com, Take a look here DR Summicron on an M8 . I'm sure you'll find what you were looking for!
a.noctilux Posted November 5, 2019 Share #2 Posted November 5, 2019 (edited) SOMNI (Summicron DR) can be used on every M (film or digital) in RF close range to 48cm with SDPOO or 1m, without the close range SDPOO. Warning for mounting/unmounting : for digital M (from M8 onward), before mount/unmount, the focus ring must be set to about 1.5m... otherwise something may be broken. Then the RF can be used to about 3-4m (depending on the digital M ) then the focus is blocked by the body, not be able to use the lens farther. Only with M10, some SOMNI can be used to infinity ( see this link ) but same warning for mount/unmount (set the lens to about 1.5m ). Better idea...for digital M and RF close range... The best way is to use only the optical cell of Summicron 50mm on SOMKY+ UOORF this way nothing to take care of, this setup can be RF used on every Leica M from start. Edited November 5, 2019 by a.noctilux Link to post Share on other sites More sharing options...
pedaes Posted November 5, 2019 Share #3 Posted November 5, 2019 On my M10 the DR focus started getting tight (in truth a horrible feeling) way before infinity, so I think this might be critical to individual bodies. I know I would never again mount any DR on a M10 I owned . FWIW. Link to post Share on other sites More sharing options...
tommonego@gmail.com Posted November 8, 2019 Author Share #4 Posted November 8, 2019 Just picked up a collapsible Summicron 50. Link to post Share on other sites More sharing options...
