otto.f Posted November 3, 2019 Share #21 Posted November 3, 2019 Advertisement (gone after registration) Aperture 16 in the sky. Mostly there will be some dust then. I’m more interested in dust that is still visible at 5.6 because I’m seldom shooting with smaller apertures than that. Dust that looks dramatic at 11 or 16 can be gone at 2.8 Link to post Share on other sites More sharing options...
Advertisement Posted November 3, 2019 Posted November 3, 2019 Hi otto.f, Take a look here Used Monochrom 246 Or wait for Monochrom M10. I'm sure you'll find what you were looking for!
Kwesi Posted November 3, 2019 Share #22 Posted November 3, 2019 1 hour ago, dimm said: How dust can be tested? Shooting white list? Dust on the sensor is the least of your problems with an MM1. Before you buy you must have proof that the MM1 has a new non-corrodible sensor installed. Otherwise you are throwing your money away. Link to post Share on other sites More sharing options...
dimm Posted November 4, 2019 Author Share #23 Posted November 4, 2019 7 hours ago, Kwesi said: Before you buy you must have proof that the MM1 has a new non-corrodible sensor installed. Otherwise you are throwing your money away. CCD ID = 53? Link to post Share on other sites More sharing options...
dimm Posted November 15, 2019 Author Share #24 Posted November 15, 2019 BTW, I got MM1 in the end. OMG, what a lovely camera. How I love it notwithstanding all the quirks. And a battery life, comparing to Q2 it's infinite 😂 1 Link to post Share on other sites More sharing options...
FrozenInTime Posted November 17, 2019 Share #25 Posted November 17, 2019 Looks like Leica are clearing out the last batch of 246MMs.- Wetzlar engraving and slight discount. https://leicarumors.com/2019/11/15/new-black-chrome-leica-m-monochrom-leitz-wetzlar-limited-edition-camera.aspx/ 1 Link to post Share on other sites More sharing options...
dimm Posted November 17, 2019 Author Share #26 Posted November 17, 2019 18 minutes ago, FrozenInTime said: Looks like Leica are clearing out the last batch of 246MMs.- Wetzlar engraving and slight discount. https://leicarumors.com/2019/11/15/new-black-chrome-leica-m-monochrom-leitz-wetzlar-limited-edition-camera.aspx/ I knew about this edition. And specifically decided to buy used MM1 in order to understand if I really need monochrom. I am completely happy with my camera 😉 Link to post Share on other sites More sharing options...
lanetomlane Posted November 22, 2019 Share #27 Posted November 22, 2019 Advertisement (gone after registration) Originally I had the M9M but upgraded to the 246 because of battery compatibility with the 240 I also had at the time. The 246 was stolen in Portugal a couple of years ago. I've just replaced it, but gone back to the M9M as I think the files from the CCD sensor have a much smoother transition through the dynamic range. Link to post Share on other sites More sharing options...
dimm Posted November 22, 2019 Author Share #28 Posted November 22, 2019 6 hours ago, lanetomlane said: The 246 was stolen in Portugal a couple of years ago Sorry for your lost. How did it happen? Link to post Share on other sites More sharing options...
lanetomlane Posted November 30, 2019 Share #29 Posted November 30, 2019 From the trunk of the car. Lost Monochrom, 50 Summilux, MATE, 75 Summicron, 28 Summicron and all accessories. On 11/22/2019 at 8:19 AM, dimm said: Sorry for your lost. How did it happen? Link to post Share on other sites More sharing options...
davidmknoble Posted December 8, 2019 Share #30 Posted December 8, 2019 Just a note on ISO between the M246 and MM1. Remember that higher ISO means higher dynamic range. If you compare S007 shots to an M9 you can see the difference in the tonal range. The MM246 allows much more shadow recovery if you are shooting for the highlights. So, if you don’t need high ISO for low light, you still get the advantage of it in other images... IMHO. Link to post Share on other sites More sharing options...
dkmoore Posted December 9, 2019 Share #31 Posted December 9, 2019 (edited) On 12/8/2019 at 9:56 AM, Outdoorimages said: Just a note on ISO between the M246 and MM1. Remember that higher ISO means higher dynamic range. If you compare S007 shots to an M9 you can see the difference in the tonal range. The MM246 allows much more shadow recovery if you are shooting for the highlights. So, if you don’t need high ISO for low light, you still get the advantage of it in other images... IMHO. your notes above are confusing. Not meant as a negative comment but I don't think most people will be able to decipher. Just an FYI in case you want to clarify. For the record, the MM246 has very good high ISO performance as would the M10M based on my usage of the M10. Edited December 9, 2019 by dkmoore Link to post Share on other sites More sharing options...
AceVentura1986 Posted December 10, 2019 Share #32 Posted December 10, 2019 M10M. It looks to be an awesome camera. I’ve never been fond of the 240 platform either. 1 Link to post Share on other sites More sharing options...
davidmknoble Posted December 10, 2019 Share #33 Posted December 10, 2019 16 hours ago, dkmoore said: your notes above are confusing. Not meant as a negative comment but I don't think most people will be able to decipher. Just an FYI in case you want to clarify. For the record, the MM246 has very good high ISO performance as would the M10M based on my usage of the M10. Good comment and thanks! All I am trying to indicate is that the MM246 has more dynamic range than the MM1, which is more than just shooting in low light. The MM246 will do a better job in bright sunlight because it will have less blown highlights and black shadows than the MM1. With proper exposure of course... I am anxious about the M10M because of both the smaller size (since I shoot film with an MP as well) and because I am sure the dynamic range will step up once again. Hope that makes more sense! 1 Link to post Share on other sites More sharing options...
dkmoore Posted December 10, 2019 Share #34 Posted December 10, 2019 33 minutes ago, Outdoorimages said: All I am trying to indicate is that the MM246 has more dynamic range than the MM1, which is more than just shooting in low light. Agreed. I still much prefer the MM1 solely for its uniqueness in image rendering. For everything else I prefer the M246. The M10M will be VERY nice. I will be purchasing 100%. 1 Link to post Share on other sites More sharing options...
