Hi
I have just had my M240 at Leica to fix a faulty SD card socket. (When I press in the card, it won't attach). Leica wanted 18000DKK (2400EUR) to fix it which is a little less than I paid for the camera. I am sure it is a very little thing that is wrong, so my question is if anybody fixes these things other than Leica them selves? Or if perhaps anybody else has experienced similar issues. I refused to pay that much, so I got it back unrepaired.
Hope you can help.
Best,
Pelle
You might want to try an electronics repair workshop instead because you're essentially dealing with a circuit board.  A memory card slot repair is bread and butter to them and shouldn't be too difficult.
If they successfully repair the slot but in the process disturb the camera's tolerances, you can send it back to Leica for adjustment.  The only problem I foresee with this method is that Leica won't accept it back.
But what do you have to lose?
Not a good idea to get non qualified repair tech to attempt repair.
I attempted to get my audio  electronics repairs by a company that repair and worked on audioelectronics but not my brand. Trying to locate  the issue they cut irreplaceable
integrated circuits to  try and isolate the issue. Now the IC cannot be repaired or replaced as the tech cut the leg of them so close to the body .
Now I have 50 pound paper weight.
Only option is find a qualified 3rd party repair tech or send back to Leica
Unfortunately, the "better" idea is going to cost 2400 Euros.
The camera is already unusable as it is, and an SD card slot is an SD card slot, what does he have to lose?
Thanks for all the tips guys.
I got it home and thought that it couldn't be right and that it must be something simple, so i gave it some firm slaps on the side, and out fell a little stone or something like that. It now works perfectly again.
Somewhat cheaper than paying 2400€...
Not the best first experience with Leica repair. I think they could have given it a look over before quoting to change all the guts of it.
Thanks again everybody.
