11 minutes ago, ash13brook said:
Are all M mount and LTM w/adapter lenses compatible with a 262.
I realize that some functions may not be available on older lenses, will they at least work in full manual mode?
Thanks,
Matt
They’ll all work fine, just like if you were using a film M.
9 minutes ago, RayD28 said:
I believe a 50mm Cron DR is not fully compatible.
True, focus only to about 10m,
infinity is not reachable with M262 and other M8/M9/M240.
But RF usable from 48cm with "goggles"... to about 10m.
M10 is the only digital Leica that I can use the 50 DR Summicron (Somni) without modification.
Precaution is always true also while mounting set the focus ring to about 1.5m before mounting.
As usual, using collapsible lenses with care (a ring of something to limit the collapsing inside the body) : not with the new Elmar-M 2.8/50 or Macro-Elmar-M 4/90 which collapsing is limited by design.
Edited by a.noctilux
The current 90mm f4 is perfectly usable and can be collapsed into any M body. It's the classic 50's and 60's lenses where the issues with the modern bodies have to be accounted for.
Edited by Gregm61
Hi All. I use both classic and modern collapsible 50mm f2.8 Elmar on my M262 and M8.2 and there is no problem to collapse them.
I'm just carefull to extend them before mounting them on the camera body.
Edited by goodtimes
Addition of advise
