sls Posted August 15, 2019 Share #1 Posted August 15, 2019 Advertisement (gone after registration) I had a Q from day of release and it was faultless, even with some accidental mistreatment. I am on my first proper travel trip with a brand new Q2. Have taken about 200 shots. On my first day on this trip it was working fine and then 30 seconds later completely dead. No power, changed batteries, SD card, just a lump of inert metal. Anyone heard of such a failure? More to the point, any ideas of a possible fix? Link to post Share on other sites More sharing options...
Advertisement Posted August 15, 2019 Posted August 15, 2019 Hi sls, Take a look here Q2 instant death . I'm sure you'll find what you were looking for!
ralphh Posted August 15, 2019 Share #2 Posted August 15, 2019 Sorry to hear about that, what a bummer! I've not seen a similar issue on here, though I've heard of a few lockups. You could try leaving it with the battery out overnight. If that doesn't fix it then I think it is probably really dead. Link to post Share on other sites More sharing options...
LexS Posted August 15, 2019 Share #3 Posted August 15, 2019 Indeed, battery out for a (long) night. If it works after that, don't forget to set the date and other settings.... Link to post Share on other sites More sharing options...
sturkel Posted August 15, 2019 Share #4 Posted August 15, 2019 Wow, talk about "infant mortality" failures- in the early life of a product adhering to the bathtub curve, the failure rate is high but rapidly decreasing as defective products are identified and discarded, and early sources of potential failure such as handling and installation error are surmounted. In the mid-life of a product—generally speaking for consumer products—the failure rate is low and constant. In the late life of the product, the failure rate increases, as age and wear take their toll on the product. Many electronic consumer product life cycles strongly exhibit the bathtub curve. Cheers Stan 1 Link to post Share on other sites More sharing options...
sls Posted August 16, 2019 Author Share #5 Posted August 16, 2019 14 hours ago, sturkel said: Wow, talk about "infant mortality" failures- in the early life of a product adhering to the bathtub curve, the failure rate is high but rapidly decreasing as defective products are identified and discarded, and early sources of potential failure such as handling and installation error are surmounted. In the mid-life of a product—generally speaking for consumer products—the failure rate is low and constant. In the late life of the product, the failure rate increases, as age and wear take their toll on the product. Many electronic consumer product life cycles strongly exhibit the bathtub curve. Cheers Stan That’s a bit too philosophical for me and doesn’t fix the Q2 problem, which is still moribund. My backup camera has nice curves but nothing relating to a bathtub, it’s a Leica III still working perfectly after 85 years. Link to post Share on other sites More sharing options...
sturkel Posted August 16, 2019 Share #6 Posted August 16, 2019 My comment was to explain how concerning this is to have this type of early event. We are a small sample here on this forum and the number of issues reported for the number of users shpuld be a concern. Wish best of luck with a replacement. Cheers 3 1 Link to post Share on other sites More sharing options...
LexS Posted August 17, 2019 Share #7 Posted August 17, 2019 Advertisement (gone after registration) any news already? Link to post Share on other sites More sharing options...
sls Posted August 17, 2019 Author Share #8 Posted August 17, 2019 (edited) 37 minutes ago, LexS said: any news already? Still dead. Leica mystified. Of course they mentioned the dreaded water damage, but after losing a camera to the Indian Ocean a few years ago I never go near water and the Q2 is meant to be water resistant, not that I plan on testing it in the shower. I cannot test it here as I’m in Morocco and it’s 44 in the shade. Plus the thing was working and dead 30 seconds later. We are near a river that is bone dry. So even if I wanted to throw it in the river out of sheer annoyance - and I am annoyed - it would be pointless as instead of a splash I’d get a dull thud and a goat would probably walk off with it. So once I’m back in the UK seems like it’s off to Germany. This camera is capturing more Airmiles than images at the moment. Edited August 17, 2019 by sls Link to post Share on other sites More sharing options...
Jared Posted August 17, 2019 Share #9 Posted August 17, 2019 44 in the shade, huh? I wonder whether your problem is heat related? The battery will only charge if the ambient temperature is below 30*C and the camera itself will only work up to 40*C. If the camera got hot enough to turn itself off? And, for some reason, isn’t re-setting? Did you mention the temperature to Leica support? Not because you did anything wrong, but maybe they could tell you some way to reset things if a temp protection circuit kicked in? Link to post Share on other sites More sharing options...
sls Posted August 17, 2019 Author Share #10 Posted August 17, 2019 1 hour ago, Jared said: 44 in the shade, huh? I wonder whether your problem is heat related? The battery will only charge if the ambient temperature is below 30*C and the camera itself will only work up to 40*C. If the camera got hot enough to turn itself off? And, for some reason, isn’t re-setting? Did you mention the temperature to Leica support? Not because you did anything wrong, but maybe they could tell you some way to reset things if a temp protection circuit kicked in? It was under 30c when I was using it in the evening and our hotel room is cool. I’ve used the Q when it was 46c in the shade, in Seville in August. I used the Q and an M Monochrom at -15c with a big windchill, when a Sony packed up. I asked Leica if there is a magic reset. Apparently not. Link to post Share on other sites More sharing options...
sls Posted August 17, 2019 Author Share #11 Posted August 17, 2019 Using this backup camera is always fun, I forgot my snippers, found a barber and borrowed a razor blade but almost had to get a haircut. They do odd haircuts here. Then some fisherman wanted a tip for a picture and I assumed the price included the fish. I realised my mistake, I should have haggled to buy the fish and asked for a photo afterwards. Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! 1 Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/300328-q2-instant-death/?do=findComment&comment=3799971'>More sharing options...
Jared Posted August 19, 2019 Share #12 Posted August 19, 2019 On 8/17/2019 at 10:52 AM, sls said: It was under 30c when I was using it in the evening and our hotel room is cool. I’ve used the Q when it was 46c in the shade, in Seville in August. I used the Q and an M Monochrom at -15c with a big windchill, when a Sony packed up. I asked Leica if there is a magic reset. Apparently not. Darn Link to post Share on other sites More sharing options...
sls Posted August 25, 2019 Author Share #13 Posted August 25, 2019 It was 48*c and humid in Marrakech yesterday. Too hot to take the lens cap off. Cannot be good for film? Link to post Share on other sites More sharing options...
sls Posted September 4, 2019 Author Share #14 Posted September 4, 2019 (edited) Took the Q2 to Leica Duke Street and was shipped to Germany and repaired under warranty in 9 days. Is that a record? Seems to have been a very rare electro-mechanical failure, I had the Q for 4 years and it was bullet-proof, one reason for getting the Q2. Edited September 4, 2019 by sls 6 Link to post Share on other sites More sharing options...
davidginNYC Posted September 4, 2019 Share #15 Posted September 4, 2019 Sorry to hear it let you down while you were traveling, but it’s great that you got it back so quickly. Here’s hoping the rest of your Q2 time is painless and glitch-free. I got mine also because the Q was so bulletproof and dependable. Link to post Share on other sites More sharing options...
ralphh Posted September 4, 2019 Share #16 Posted September 4, 2019 3 hours ago, sls said: Took the Q2 to Leica Duke Street and was shipped to Germany and repaired under warranty in 9 days. Is that a record? Seems to have been a very rare electro-mechanical failure, I had the Q for 4 years and it was bullet-proof, one reason for getting the Q2. Very encouraging! Link to post Share on other sites More sharing options...
sls Posted February 20, 2020 Author Share #17 Posted February 20, 2020 Q2 failed again. This time malfunctioning that was intermittent, made it pretty useless, and it did it in front of two Leica salespeople in Duke Street. Camera went to Germany who thought it was OK, but I suggested if it was returned to me, as it was only 6 months old I'd just take it to the store and ask for my money back. Sale of Goods Act 1979 and all that stuff. Thanks to some very good people at Leica in London, I have just received a replacement. All in, inside three weeks. Thank you Leica. Think this was a one-off manufacturing fault, personally I think it was in or around the shutter button. I'll never know, but pleased to have it back and V2.0 was icing on the cake. Link to post Share on other sites More sharing options...
Leica Guy Posted February 20, 2020 Share #18 Posted February 20, 2020 40 minutes ago, sls said: Q2 failed again. This time malfunctioning that was intermittent, made it pretty useless, and it did it in front of two Leica salespeople in Duke Street. Camera went to Germany who thought it was OK, but I suggested if it was returned to me, as it was only 6 months old I'd just take it to the store and ask for my money back. Sale of Goods Act 1979 and all that stuff. Thanks to some very good people at Leica in London, I have just received a replacement. All in, inside three weeks. Thank you Leica. Think this was a one-off manufacturing fault, personally I think it was in or around the shutter button. I'll never know, but pleased to have it back and V2.0 was icing on the cake. Glad to hear you’re back in business. Link to post Share on other sites More sharing options...
PhotoCruiser Posted February 20, 2020 Share #19 Posted February 20, 2020 Shit happnz, i had several of this issues with several manuafcturers and gear including a brand new ASUS laptop. Instant child death, electronic gear usually breaks immediately or then after a long time. Important is that LEICA first fixed and then replaced the camera, thats the correct behaviour of a a prime camera manufacturer. Chris Link to post Share on other sites More sharing options...
