scjohn Posted July 30, 2007 Share #1 Â Posted July 30, 2007 Advertisement (gone after registration) I recently purchased John Milich's adapter for the cv 15. it comes with nicely machined "holes" that I can use to self-code. I believe there was a thread on this. What pattern should I use for the CV 15 and what kind of paint should I use? Â As always any help and advice would be GREATLY appreciated! Link to post Share on other sites More sharing options...
Advertisement Posted July 30, 2007 Posted July 30, 2007 Hi scjohn, Take a look here self-coding a milich adapter for cv15. I'm sure you'll find what you were looking for!
grdglass Posted July 30, 2007 Share #2  Posted July 30, 2007 It's here:  Leica M8 Lens Codes  Helene Link to post Share on other sites More sharing options...
doubice Posted July 30, 2007 Share #3 Â Posted July 30, 2007 ..... what kind of paint should I use? Â I used model railroading paint - have a good supply at home as we all need more than one hobby. Â Best is to use paint which is water based, for easier clean-up. Gloss black and gloss white worked for me. Â Good luck, Â Jan Link to post Share on other sites More sharing options...
farnz Posted July 30, 2007 Share #4 Â Posted July 30, 2007 Stephen, Â To build on Helene's response you need to code your CV15 as the Tri-Elmar-M 16-18-21 (No. 11626). Â Pete. Link to post Share on other sites More sharing options...
scjohn Posted July 30, 2007 Author Share #5 Â Posted July 30, 2007 Thank you everyone. This is sure a fine forum! Actual knowledge... what a novelty! Link to post Share on other sites More sharing options...
grdglass Posted July 30, 2007 Share #6 Â Posted July 30, 2007 And to add some more, when you have it coded, a menu will pop-up giving you a choice of 16-18-21mm. Select 16mm for the CV15. Â It seems that certain paints work for some people and other paints are needed by others. Some have luck with glossy black and white nail polish. Some need matte black and white model paint. Some must use black and white, and some use only black. Â Don't get discouraged if one method doesn't work for you. Just try the others. Be certain to completely fill in the holes. Â Good luck. Â Helene Link to post Share on other sites More sharing options...
doubice Posted July 30, 2007 Share #7 Â Posted July 30, 2007 Advertisement (gone after registration) And to add some more, when you have it coded, a menu will pop-up giving you a choice of 16-18-21mm. Select 16mm for the CV15. Â This only happens if Lens Recognition is set On + UV/IR, at least with the latest firmware (1.107), I did not try it with 1.102. Â Best, Â Jan Link to post Share on other sites More sharing options...
