On 5/29/2019 at 1:18 PM, Trev said:
Magic
i bought 8mm outer, 5mm inner at 1.5 thickness. Tight fit, but works perfectly.
I'm glad my suggested DIY is a help. Leica engineers should have spent more time on the flawed On/Off switch instead of wasting time on nonsense like Nikki Sixx and Kravitz edition leicas.
Thank you. Extremely well said. Are you listening Leica?
Completely different development teams on the Q vs the M. Wouldn't change a thing. Leica is not a "six guys in the garage" company. :D
Edited by ramarren
Not to be argumentative but the "Nikki Sixx" is a Q model. My broader point was less emphasis on Leica being a "fashion accessory" and more of a pro/enthusiasts camera.
I’ve never bought a Leica as a fashion accessory. I’ve always bought them to make photographs with, both for my private and professional needs.
For me, they are just good cameras that I like. I like other good cameras too. I have no problem seeing them make specials for those that want them. I still don’t think the design of specials impacts the standard production in any significant way.
  • 1 month later...
On 5/29/2019 at 6:18 PM, Trev said:
Magic
21 hours ago, codocee said:
Doesn't work on the original Q. There is no gap between the switch and top plate.
Still experimenting!
Honestly. Works for me.
  • 2 months later...
I’m new to the forum. I just bought a Q-P, and like it a lot. But I immediately noticed how easily the power switch turns on the camera, in a bag or by brushing against it. I followed suggestion of Matsaly and fitted a neoprene O-ring over it. The ring certainly stabilises the switch. But I wonder if there is a risk that the O-ring will cause  stress on the physical mechanism of the switch, by repeated use of on/off. Could it eventually cause another issue by friction between the DIY rubber ring and the workings of the switch?
  • 4 weeks later...
  • 2 years later...
On 5/17/2019 at 12:48 PM, Matsaly said:
I bought the following on Amazon. Litorange 580PCS Silicone 45A Universal Red O-Ring Sealing Gasket. I don't have the box in front of me but if I recall the 2nd to smallest O-Ring was the perfect size.
I imagine you could use the smallest size O-Ring in that box set for a more "discreet" look, but I wanted part of the O-Ring to be visible (and ready accessible) if I wanted to remove it.
Hi,
It's been a while since I did the DIY install. To date no issues whatsoever (That said I hardly ever use the Q-P since having purchased a Q2).
I don't recall using any tools whatsoever. Tweezers might help. If you go back to my original posts you will see the "approximate" dimension s of the O rings I used.
