I've borrowed a friends Q.  Really impressed with the camera but I had one question.  When using AF, is there anyway to automatically bring the green focus box back to the center of the frame.  I can do this with my Fuji X100F by pressing in on the joy stick.  Thanks--I'm seriously thinking of buying one of these.
I think you'll find that a quick double tap anywhere on the rear screen should do that.
Stephen
  • Thanks 6
Stephen
Thanks so much. Just tried it. It’s been bugging me since I left Fuji.
  • 4 weeks later...
Stephen
thank you!! but then is there any button other than tapping the screen??
vor 5 Stunden schrieb DexL:
[...] Maybe return to center at startup could be another firmware request.
vor 5 Stunden schrieb PaulJS:
You can’t on the Q2, drives me nuts.......
I think this is a "feature" that is really useful sometimes. Just imagine this situation: You shoot a series of portraits and want the left eye to be in focus and the face in the middle of the frame. Of course, you shift the focus box away from the centre (to the eye). Wouldn't it really bother you if you had to find that same spot for that focus box every time you have a break and turn the camera off. I prefer being able to turn off the camera from time to time (...when shooting a wedding? ...in a studio with a fixed setup?) to save battery power, knowing that for the next portrait, the focus box is still where I need it for the next shot.
Besides, I think that double-tapping the screen is much easier and faster than turning the camera off and on and wait for the restart (although that restart is really fast).
After the double tap you can fix the focus point via Menu-Focusing-Touch AF. I use my left eye, in German "Ein Linkseinblicker" always difficult with Leica M. Now with the Q2 my nose too often chooses a focus point in the bottom left corner. The touch sensitivity of the screen is imo a superfluous function unless the sensitivity can be set and adjusted separately. On the M8 M9 and M240 I didn't miss it.
2 hours ago, jeff_m said:
I only use the Q2 in EVF mode so no LCD image on the back. Is there a quick way to move the center focus point for this set-up?
That was kinda my point as well being an evf shooter.  Again hoping for firmware update solution.
Am 14.6.2019 um 05:46 schrieb DexL:
I use extended EVF mode. Often I find myself looking through the viewfinder and at the same time double-tapping on the (probably) black screen. Of course nothing happens...
tk
