Learner Posted May 2, 2019 Share #1 Posted May 2, 2019 Advertisement (gone after registration) I have been charging the Q2 battery for about 6 hours.... 80% was achieved fairly quickly... less than two hours. The 80% light is still showing... Should it not go out when full charge is achieved? Link to post Share on other sites More sharing options...
Advertisement Posted May 2, 2019 Posted May 2, 2019 Hi Learner, Take a look here Confused by battery charging lights . I'm sure you'll find what you were looking for!
IkarusJohn Posted May 2, 2019 Share #2 Posted May 2, 2019 We had a member here for a while who used this forum as a substitute for getting off his backside and reading the manual. It got old very quickly. I don't have a Q2, but I suspect its charger is the same as all other Leica chargers - you get a green light until it achieves 80%, then you get the additional light (from memory). With a new battery, charge it overnight, run it flat, then charge it overnight - battery performance will improve quite quickly. The lights are indicative of 80% only - they seem to do their own thing. They don't go out. I'm sure the online manual will give a more accurate description ... 2 Link to post Share on other sites More sharing options...
jeff_m Posted May 2, 2019 Share #3 Posted May 2, 2019 From the manual. Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/296825-confused-by-battery-charging-lights/?do=findComment&comment=3732945'>More sharing options...
LocalHero1953 Posted May 2, 2019 Share #4 Posted May 2, 2019 (edited) 4 hours ago, IkarusJohn said: We had a member here for a while who used this forum as a substitute for getting off his backside and reading the manual. It got old very quickly. I don't have a Q2, but I suspect its charger is the same as all other Leica chargers - you get a green light until it achieves 80%, then you get the additional light (from memory). With a new battery, charge it overnight, run it flat, then charge it overnight - battery performance will improve quite quickly. The lights are indicative of 80% only - they seem to do their own thing. They don't go out. I'm sure the online manual will give a more accurate description ... Not in my experience. The SL, CL and TL2 chargers all behave differently. - CL: continuous green light till it's charged, when it goes out. No 80% light. - TL2: red light till it's charged; it's still charging so I can't remember what happens then - I think it goes green. No 80% light. - SL: green flashing light while charging, with a secondary light for 80% charge; green light goes continuous at 100%. I find this random variability mildly but regularly irritating in a way that only Leica manages to achieve (like lens caps and hoods). I can't always remember which charger behaves in which way, and can't be bothered to find and check the manual each time. Yes, I can guess, but if I accidentally put a charged battery in, I get confused because I'm unsure what the lights are telling me. I doubt Leica makes its own chargers, but even if a series of different third party factories in China makes them based on a standard model, I would have thought LED behaviour would form part of the specification for custom adaptation. Edited May 2, 2019 by LocalHero1953 Link to post Share on other sites More sharing options...
IkarusJohn Posted May 2, 2019 Share #5 Posted May 2, 2019 I confess, I never really look. I just chuck the dead battery in the charger overnight. 1 Link to post Share on other sites More sharing options...
Learner Posted May 2, 2019 Author Share #6 Posted May 2, 2019 Thank you gentlemen. Link to post Share on other sites More sharing options...
LexS Posted May 2, 2019 Share #7 Posted May 2, 2019 Advertisement (gone after registration) If the charging takes "too" long the first time: disconnect the charger, take the battery out, then put the battery in again, and connect the charger. Link to post Share on other sites More sharing options...
Matsaly Posted May 2, 2019 Share #8 Posted May 2, 2019 There are aftermarket battery chargers that may offer a solution to your concerns. I bought the Nitecore USB battery charger for my Q. IMHO its a far more elegant and versatile solution than the stock Leica charger. Disclosure- I have no commercial or financial interest in Nitecore or any other aftermarket brand. Just sharing my "users" experience. Miami Leica store has the various Nitecore chargers on their website. https://leicastoremiami.com/collections/charging-solutions/products/nitecore-usb-battery-charger-ulsl-for-leica-sl-typ-601?variant=10394025033772 2 Link to post Share on other sites More sharing options...
jaapv Posted May 3, 2019 Share #9 Posted May 3, 2019 On 5/2/2019 at 3:30 AM, Learner said: I have been charging the Q2 battery for about 6 hours.... 80% was achieved fairly quickly... less than two hours. The 80% light is still showing... Should it not go out when full charge is achieved? No- it shoudn't. What difference does it make? Link to post Share on other sites More sharing options...
ramarren Posted May 3, 2019 Share #10 Posted May 3, 2019 I have both the Nitecore chargers and the Leica OEM chargers for my M-D and CL batteries. They both work well, but I find the Leica OEM charger actually achieves a slightly greater amount of charge on a full charge cycle. I think the Nitecore chargers are a bit more conservative about what constitutes full charge to help protect the battery and prolong battery life. Yeah, when I charge things, I just drop them in and pull them out the next morning. I don't look at the lights much. Link to post Share on other sites More sharing options...
reynoldsyoung Posted May 4, 2019 Share #11 Posted May 4, 2019 The 80% light stays on after the green stops blinking and goes solid....then, you are fully charged. 1 1 Link to post Share on other sites More sharing options...
bullmoon Posted July 3, 2019 Share #12 Posted July 3, 2019 On 5/3/2019 at 8:56 PM, reynoldsyoung said: The 80% light stays on after the green stops blinking and goes solid....then, you are fully charged. That's what mine is doing now - but, I don't really get that from reading the manual. Good to know that's normal. The first time I charged it, the 80% light didn't stay on - and after a time all the lights were off, but I only have seen that behavior the first charge out of the box. Link to post Share on other sites More sharing options...
AnikiMu Posted July 4, 2019 Share #13 Posted July 4, 2019 On 5/2/2019 at 3:30 AM, Learner said: I have been charging the Q2 battery for about 6 hours.... 80% was achieved fairly quickly... less than two hours. The 80% light is still showing... Should it not go out when full charge is achieved? No: Orange and green lights on at 100% 2 Link to post Share on other sites More sharing options...
