kentishrev Posted April 13, 2019 Share #1 Posted April 13, 2019 Advertisement (gone after registration) Help! I changed the SD card in my CL. It felt a bit solid as I pushed, so tried to take it out again. No luck. It’s stuck. On the plus side, it is working. But that’s not really the point! Has this happened to anyone else? Easy solution possible? Quote Link to post Share on other sites More sharing options...
Advertisement Posted April 13, 2019 Posted April 13, 2019 Hi kentishrev, Take a look here SD card stuck in CL. I'm sure you'll find what you were looking for!
rob_w Posted April 13, 2019 Share #2 Posted April 13, 2019 It did happen to me. New CL, new card. I pushed it in to trigger the release then gently eased it out with a pair of long-nose pliers. As long as the release mechanism can be triggered, I figured it should come out easily enough, which it did, as it was only a bit of friction. But I was very gentle with the pull. Any resistance, I would have stopped. There was nothing wrong visually with the SD card (a Sandisk 128Gb recommended by a forum member in the Q&A section) so I smoothed the edges with my finger nail and then tried inserting and releasing it 10 or so times in the SD slot on my laptop. Now works fine in the CL. Hope this helps! 1 1 Quote Link to post Share on other sites More sharing options...
kentishrev Posted April 13, 2019 Author Share #3 Posted April 13, 2019 4 hours ago, rob_w said: As long as the release mechanism can be triggered, I figured it should come out easily enough, which it did, as it was only a bit of friction. But I was very gentle with the pull. Any resistance, I would It worked, thank you. Tweezers did it. Seems fine now! Quote Link to post Share on other sites More sharing options...
rob_w Posted April 13, 2019 Share #4 Posted April 13, 2019 Glad to hear that! After I posted I worried I might encourage a dangerous action -- phew! 😅 1 1 Quote Link to post Share on other sites More sharing options...
JayBird Posted April 13, 2019 Share #5 Posted April 13, 2019 7 hours ago, rob_w said: It did happen to me. New CL, new card. I pushed it in to trigger the release then gently eased it out with a pair of long-nose pliers. As long as the release mechanism can be triggered, I figured it should come out easily enough, which it did, as it was only a bit of friction. But I was very gentle with the pull. Any resistance, I would have stopped. There was nothing wrong visually with the SD card (a Sandisk 128Gb recommended by a forum member in the Q&A section) so I smoothed the edges with my finger nail and then tried inserting and releasing it 10 or so times in the SD slot on my laptop. Now works fine in the CL. Hope this helps! I have a Sandisk SD card that did the same thing. I was hesitant to do what you tried but will give it a go. Thanks for trying. Quote Link to post Share on other sites More sharing options...
b55er Posted April 20, 2019 Share #6 Posted April 20, 2019 And another one here..new CL, easy pull with needle nose pliers. I smoothed the edges of the SanDisk SDXC with a the rough end of a kitchen ScotchBright pad. Works fine now. Someone’s tolerances are off.. Quote Link to post Share on other sites More sharing options...
kentishrev Posted April 20, 2019 Author Share #7 Posted April 20, 2019 Advertisement (gone after registration) Just to confirm, mine was Sandisk as well. Quote Link to post Share on other sites More sharing options...
AndyDP Posted February 18, 2022 Share #8 Posted February 18, 2022 Its still a problem in Feb 2022! I just inserted a brand new SanDisk Extreme Pro 128GB. Old 64GB cards fine. Mind put at rest after finding your forum. Thanks Quote Link to post Share on other sites More sharing options...
