M8 - File Problem
Guest Essemmlee
Wilson isn't quite correct with regards to Image Capture (with respect!)
You don't need to run it in the background. What you can do, and what probbaly happens the first time you run it, is set the Preferences within Image Capture to always perform a certain task when a camera or card is detected. This would normally be iPhoto, but mine is set to open Lightroom by default, as soon as a card is inserted into a reader. Image Capture doesn't need to be running, as the preference is set System-wide.
I only ever use Image Capture to scan documents on my flat-bed scanner.
Well I never.
Thanks to Wilson for the Image capture information. Where does it say this in the manual? It worked perfectly. The files are still buggered though; they are transferred directly from the camera but still not read.
Steve,
The information is on page 122 of the manual. Sadly you have to translate it into German and back again into English (but correctly this time) for it to make sense, otherwise the Mac/USB instructions are garbage. I asked Leica UK back in January to put an Errata Sheet into the manual or at least to correct the PDF file but I see neither seems to have been done yet - Ho Hummmm.
Wilson
Guest Essemmlee
As a new M8 user it is easy to become frustrated with the errant behaviour of the whole global system, the camera, lenses, software, computers and the relationships between them all.
It's a good job there are decent folk on this forum to help 'cos I'm sure the looney bin would have beckoned.
Andy,
I sort of got the impression Image Capture was acting like a TSR (Terminate but Stay Resident) program in Windows - I don't know the terminology in OS X and in effect pointed the images at the correct program - in my case C1 for DNG's, iPhoto for JPEG's. I agree it only opens actively in certain scanner operations, which was a real nuisance in my case, as I wanted Canon's own sub-program, Canoscan, to run and Image Capture kept opening up but only on my PowerMac and not on the iMac or iBook.
Wilson
Steve--Or take up meditation :p
... with regards to Image Capture ... the first time you run it, ... set the Preferences within Image Capture to always perform a certain task when a camera or card is detected. This would normally be iPhoto, but mine is set to open Lightroom by default, as soon as a card is inserted into a reader.
Andy--
I had turned off Image Capture to maintain control, but I don't know that that actually accomplishes anything.
Do you see a specific reason to use Image Capture rather than manually dragging to my 'to process' folder?
Thanks!
--HC
Can you post one of the "bad" files somewhere where it can be downloaded? Maybe one of us would have better or different luck using a different computer, different software, etc. It seems strange that the file size would be right but the files are inaccessible. If possible, looking at one of the files with File Buddy might tell you something.
Bill
Guest Essemmlee
I have deleted all the files except one (for research purposes) as I wasn't getting anywhere. In fact I have been out today and retaken about half of them. I'll finish off tomorrow before the madhouse beckons further.
If someone knows of somewhere I can send a 10Mb file for analysis I'll be happy to provide it.
I'm not paranoid, but everyone's out to get me.
I'd be interested to see if I can read the file, I have several RAW programs I'm able to try. If you wish you can send the file as an email attachment to leica@dodo[dot]demon[dot]co[dot]uk
No promises though :D
Bob.
Steve,
You could join YouSendIt - Send large files - transfer delivery - FTP Replacement - its free for the basic service and post it there to see if any of our resident genii can decrypt it.
Wilson
Andy--
Thanks!
--HC
No. It's all down to personal preference. All I use Image Capture for is to set the System-wide pref such that inserting a card opens Lightroom.
