LUF Admin Posted March 8, 2019 Share #1 Posted March 8, 2019 Advertisement (gone after registration) Leica Q2: Technical Specifications Camera type: 35 mm digital compact camera, fixed prime lens Format / aspect ratio: 24 x 36 mm / 3:2 Lens: Leica Summilux 28 mm f/1.7 ASPH.,11 elements in 9 groups, 3 aspherical elements Digital zoom: 28 mm, 35 mm, 50 mm, 75 mm Image stabilisation: Optical shake compensation system for still picture and video exposures Aperture range: 1.7 to 16 in 1⁄3 EV increments Image sensor/resolution: Full frame CMOS sensor, 50.4/47.3 million pixels (total/effective) Dynamic range: 14 stops Colour depth: 14-bit Photo file formats: Selectable: DNG, DNG + JPEG, JPEG. Video recording formats: MP4 (C4K/4K/Full HD) Video resolution/frame rate: 4K: 30 or 24 fps. C4K: 24 fps. Full HD 24, 30, 60 or 120 fps Audio recording format: AAC Microphone: Stereo Speaker: Mono Storage media: SD/SDHC/SDXC memory cards Recommended: UHS II memory cards ISO settings: Automatic, ISO 50, ISO 100, ISO 200, ISO 400, ISO 800, ISO 1600, ISO 3200, ISO 6400, ISO 12500, ISO 25000, ISO 50000 White balance: Automatic, presets for: daylight, cloudy, shade, incandescent, electronic flash, grey card, manual colour temperature selection Colour spaces: sRGB / Adobe RGB / ECI RGB V.2.0 JPG settings: Standard, vivid, natural, monochrome, high-contrast monochrome, all with further settings for contrast, saturation and sharpness in 5 steps Focusing Working range: 30 cm to ∞, close focus distance 17 cm in macro mode Settings: Automatic (autofocus) or manual focusing. Loupe function and edge highlighting (focus peaking) available as focusing aids in manual focusing mode. Autofocus modes: AFS (shutter release only after successful focusing), AFC (shutter release possible at any time), AF setting can be saved. Autofocus metering modes: Single field (225 fields), multi-field, face recognition, subject tracking Exposure modes: Programme AE, aperture priority, shutter speed priority and manual setting Scene modes: Automatic, sport, portrait, landscape, night portrait, snow/beach, fireworks, candlelight, sunset, digiscoping, miniature effect, panorama and HDR Exposure metering modes: Multi-segment, centre-weighted, spot Exposure compensation: ± 3 EV in 1/3-EV increments Automatic exposure bracketing: 3 or 5 exposures in steps of up to 3 EV, can be set in 1⁄3 EV increments Shutter type: Choice of mechanical, electronic or hybrid Shutter speeds: 60 s to 1⁄2000 s with mechanical shutter, 1 s to 1⁄40000 s with electronic shutter, in 1/3 increments, Flash synchronisation up to 1⁄500 s, linear flash with all shutter speeds faster than 1⁄500 s (with HSS-capable SCA 3002 flash units). Continuous shooting: Choice of 10/5/3 fps (H/M/L) Self-timer delay: 2 or 12 seconds OLED viewfinder: Resolution: 1280 x 960 pixels x 3 colours (= 3.68 megapixels). Viewfinder image: approx. 100%, aspect ratio: 4:3, eye-relief: 21 mm. Adjustable between -4 and +3 dioptres, with eye-sensor for switching between viewfinder and monitor screen Monitor screen: 3" TFT LCD monitor screen with approx. 1,040,000 image dots, touch control capability WLAN: IEEE 802.11b/g/n compliant (standard WLAN protocol), channels 1-11, encryption method: WLAN-compatible WPA™/WPA2™ encryption; access mode: infrastructure mode Bluetooth: Bluetooth LE Power supply: Leica BP-SCL4 lithium-ion battery, rated voltage: 7.2V, capacity: 1860 mAh Charger: Rated voltage 8.4 V; capacity at least 1860 mAh; charging time: approx. 180 min.; battery charger: 100–240 V, 50/60 Hz, 0.25 A, with adapters Exposures per battery charge: Approx. 350 Body: Robust, lightweight magnesium alloy construction Lens filter thread: E49 Tripod bush: A 1/4 DIN 4503 (1/4" thread). Dimensions (W x H x D): 130 mm x 80 mm x 91.9 mm Weight: 734 g / 652 g (with / without battery) Package includes: Camera, carrying strap, lens hood, lens cap, accessory shoe cover, battery charger, mains power cable (EU, US, local power cable) Software: Leica FOTOS App 1 Link to post Share on other sites More sharing options...
Advertisement Posted March 8, 2019 Posted March 8, 2019 Hi LUF Admin, Take a look here Leica Q2: Technical Specifications . I'm sure you'll find what you were looking for!
