S.Rolf Posted November 20, 2018 Share #1 Posted November 20, 2018 Advertisement (gone after registration) I’ve read the manual and cannot determine what that very small illuminated dot is next to the meter lights. It’s located to the left of the meter arrow/triangle when half depressing the trigger button. Like this below. • < o > Thanks Link to post Share on other sites More sharing options...
Advertisement Posted November 20, 2018 Posted November 20, 2018 Hi S.Rolf, Take a look here That Red Light Next To The Meter . I'm sure you'll find what you were looking for!
jdlaing Posted November 20, 2018 Share #2 Posted November 20, 2018 45 minutes ago, S.Rolf said: I’ve read the manual and cannot determine what that very small illuminated dot is next to the meter lights. It’s located to the left of the meter arrow/triangle when half depressing the trigger button. Like this below. • < o > Thanks I believe that’s the Metering Memory Lock indicator. Try Page 170. Link to post Share on other sites More sharing options...
S.Rolf Posted November 20, 2018 Author Share #3 Posted November 20, 2018 I’ll check that out. Thank you. Link to post Share on other sites More sharing options...
jdlaing Posted November 20, 2018 Share #4 Posted November 20, 2018 (edited) 39 minutes ago, S.Rolf said: I’ll check that out. Thank you. I think, basically, that when you half press the shutter after metering on an area you like you can move around to re-frame and as long as you don’t release the shutter button the metering stays locked and that red dot tells you that. Also Pages 210 and 211 has some info on what it means if the dot is high or low. Edited November 20, 2018 by jdlaing Link to post Share on other sites More sharing options...
adan Posted November 20, 2018 Share #5 Posted November 20, 2018 Actually, there should be TWO tiny red dots, one above the other. But neither of them are "to the left" of the left meter arrow. They are above and below it. Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! The top one, as jd, says, shows that the shutter button is half-pressed and locking the auto-chosen shutter speed (not shown if a manual shutter speed is set). The bottom one shows that exposure compensation is set to something other than zero. Does show in manual mode 2 3 Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! The top one, as jd, says, shows that the shutter button is half-pressed and locking the auto-chosen shutter speed (not shown if a manual shutter speed is set). The bottom one shows that exposure compensation is set to something other than zero. Does show in manual mode ' data-webShareUrl='https://www.l-camera-forum.com/topic/291596-that-red-light-next-to-the-meter/?do=findComment&comment=3634380'>More sharing options...
S.Rolf Posted November 20, 2018 Author Share #6 Posted November 20, 2018 Yes. Correction, The top one is illuminated only when half-depressed. Link to post Share on other sites More sharing options...
jdlaing Posted November 20, 2018 Share #7 Posted November 20, 2018 Advertisement (gone after registration) 1 minute ago, S.Rolf said: Yes. Correction, The top one is illuminated only when half-depressed. Now set the exposure comp to plus or minus three and half press. What do you see? Link to post Share on other sites More sharing options...
S.Rolf Posted November 20, 2018 Author Share #8 Posted November 20, 2018 Ah-Ha! Took a while to figure out the operation using the half depressed button and thumb wheel but I now see the flashing light on the bottom and the steady light on top. Also see my EV indicator as well. Thanks a bunch!! Link to post Share on other sites More sharing options...
jdlaing Posted November 21, 2018 Share #9 Posted November 21, 2018 2 hours ago, S.Rolf said: Ah-Ha! Took a while to figure out the operation using the half depressed button and thumb wheel but I now see the flashing light on the bottom and the steady light on top. Also see my EV indicator as well. Thanks a bunch!! You’ve mastered the indicator. It’s the same on M-240. Link to post Share on other sites More sharing options...
@ndy_ellis Posted November 24, 2018 Share #10 Posted November 24, 2018 I love this stuff - how sad am I! Link to post Share on other sites More sharing options...
