I've photographed down to -20 degrees C with an M3 (I'm certain others have done it in colder temperatures). This was in Korea. I didn't notice any issues other than the film was very brittle, so I took care winding it on, but no problems with the film occurred.
thank you for the information..yes around -15 to -20celsius.
In your list, I'd not use IIIc, as the shutter mechanism is older style (if I remember well, must be treated by factory back then, for cold weather use).
IIIf if it's with old type shutter may have trouble,
if your IIIf is Red Dial type (new kind of shutter), may be ok.
I've used IIIg about -15 °C and the other film M had never trouble, less than digital M plus cold battery.
Benefit of using "button wind/rewind" in cold weather is not to damage film with "rapid wind lever".
M5 to be kept near body if the light meter is used (to keep it's battery warm).
Edited by a.noctilux
typo
I've never had a camera problem with any of my cameras in cold weather, but that is probably because I typically keep the cameras inside my jacket until I take a shot, providing a moderate temp for it. For me the bigger issue is occasional fogging the eyepiece due to the temperature differential between my forehead/eye and the colder temperature of the eyepiece. A little practice and the issue is usually quickly resolved.
