scott kirkpatrick Posted October 4, 2018 Share #1 Posted October 4, 2018 Advertisement (gone after registration) I've been pleased with the NiteCore chargers that I have been using for the SL and CL, and an M10 charger has been promised for some time. Well, it was announced a few weeks ago, but still does not show up on B&H or in the Leica Stores' websites. I've ordered one from NiteCore directly through their Store website. It has the same price, but supports charging one or two batteries at the same time. I don't know when it will arrive, as it says this is a pre-order. I have no business connection here, but thought others might also have been waiting for this... 1 Link to post Share on other sites More sharing options...
Advertisement Posted October 4, 2018 Posted October 4, 2018 Hi scott kirkpatrick, Take a look here M10 battery chargers. I'm sure you'll find what you were looking for!
jkcampbell2 Posted October 5, 2018 Share #2 Posted October 5, 2018 I've been using a Nitecore charger with my M9 for a couple years. I see the new M10 charger is a dual slot, nice to be able charge two batteries at once but for travel I wish they would make a smaller single slot version also. Either way they are great chargers and half the price of the OEM charger. Cheers, jc 1 Link to post Share on other sites More sharing options...
pico Posted October 5, 2018 Share #3 Posted October 5, 2018 the new M10 charger is a dual slot, Dual slot, Really? Are sure? Link to post Share on other sites More sharing options...
derleicaman Posted October 5, 2018 Share #4 Posted October 5, 2018 Here is the link to their website. Dual slot. I would also like to see a smaller one slot option. https://charger.nitecore.com/product/ulm10pro Link to post Share on other sites More sharing options...
xiaoheli Posted October 5, 2018 Share #5 Posted October 5, 2018 (edited) I just bought one using AliExpress. Will probably take some time for shipping to Europe (since shipping is free... ) will see but I am happy to finally see them released, my ULM9 was excellent companion and give me more info like battery capacity and travel freedom than Leica original charger... https://flashlight.nitecore.com/product/ulm10pro Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Edited October 5, 2018 by xiaoheli 1 Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/290189-m10-battery-chargers/?do=findComment&comment=3606586'>More sharing options...
Guest Posted October 5, 2018 Share #6 Posted October 5, 2018 Leica Store Miami have them in stock ($60) though I bought mine via eBay earlier. Link to post Share on other sites More sharing options...
scott kirkpatrick Posted October 5, 2018 Author Share #7 Posted October 5, 2018 Advertisement (gone after registration) I think the dual slot is because the M10 batteries are much smaller. I've got three, and don't usually get that many for one camera. Link to post Share on other sites More sharing options...
scott kirkpatrick Posted November 7, 2018 Author Share #8 Posted November 7, 2018 (edited) Reopening this thread, as comments on the NiteCore line are now scattered. The problems, or limitations, that have surfaced are inconsistent charging performance when a battery is only slightly discharged (sometimes Nitecore doesn't bother to continue) or when you try to use a cellphone brick, some laptops, or other low-current transformer as your USB power source. What is seen is that the NiteCore will only get 300 mA charge current into the battery, and will only charge one M10 battery at a time. When supplied from, e.g. an Apple iPad charger that is capable to 2-3 A output current, the charger can charge at 1 amp for a single battery or do two M10 batteries simultaneously at 700 mA each. The Nitecores appear to have a simpler charging profile than Leica's chargers. They charge fast, but stop a bit early for safety reasons. Thus a battery may register only 80-90% full on an M10's gauge when Nitecore says it is finished charging. When I put such a battery onto a Leica charger, it trickle-charges for another 30-60 minutes, with the yellow light on, and then registers 100% on the M10. Although the M10 Nitecore charger appears to have a slower finishing profile than the earlier models, the same result occurs. TLDR: Nitecore chargers do what they are designed to do; they are quick and cost less; Be aware of the limitations. Edited November 7, 2018 by scott kirkpatrick 2 2 Link to post Share on other sites More sharing options...
Guest Posted November 8, 2018 Share #9 Posted November 8, 2018 18 hours ago, scott kirkpatrick said: What is seen is that the NiteCore will only get 300 mA charge current into the battery, and will only charge one M10 battery at a time. Scott, I think what you are quoting is for Standard mode only? The NiteCore ULM10 varies the output current depending on the input power from the USB source, and has 2 charging modes: QuickCharge 2.0 mode and Standard mode: - In QC mode, the ULM10 will charge 2 batteries simultaneously at max 800mA in either slot...or 1 battery at 1200mA. - In Standard mode, it will charge each battery sequentially at max 700mA. Link to post Share on other sites More sharing options...
scott kirkpatrick Posted November 8, 2018 Author Share #10 Posted November 8, 2018 I haven't tried to charge two batteries at a time, and I haven't set it to quick mode (does that happen automatically, or is there a switch. It's pretty quick as it is. All I was really aware of so far is that my cellphone USP chargers don't provide enough current for any of the fancy stuff that NiteCore advertises, so I use an iPad -USB charger instead. Link to post Share on other sites More sharing options...
Guest Posted November 12, 2018 Share #11 Posted November 12, 2018 On 11/8/2018 at 2:25 PM, scott kirkpatrick said: I haven't tried to charge two batteries at a time, and I haven't set it to quick mode (does that happen automatically, or is there a switch. It's pretty quick as it is. All I was really aware of so far is that my cellphone USP chargers don't provide enough current for any of the fancy stuff that NiteCore advertises, so I use an iPad -USB charger instead. you need a Quick Charge enabled input (ie wall charger or power bank with Quick Charge technology). https://en.wikipedia.org/wiki/Quick_Charge Link to post Share on other sites More sharing options...
