zeitz Posted October 1, 2018 Share #1 Posted October 1, 2018 Advertisement (gone after registration) The M8 has a back-up battery on the main card inside the camera that holds the date / time and settings when the main battery is removed. Does the back-up battery ever have to be changed? As a reference my Nikon D2x has a CR1616 battery that serves this function, the camera tells the user if it needs to be changed, and the CR1616 is easy to get at for the change. I'm just curious about the situation with my 12 year old M8. I'd hate to have to send the camera to Leica just to have this battery changed. Link to post Share on other sites More sharing options...
Advertisement Posted October 1, 2018 Posted October 1, 2018 Hi zeitz, Take a look here M8 Built-in Back-up Battery. I'm sure you'll find what you were looking for!
pico Posted October 1, 2018 Share #2 Posted October 1, 2018 The Leicas have a small chip that remembers certain things even if the battery fails. Link to post Share on other sites More sharing options...
zeitz Posted October 2, 2018 Author Share #3 Posted October 2, 2018 Interesting, Pico. But while non-volatile memory could save the settings, it could not power a clock for date / time. I still have the question, does the back-up battery ever have to be changed? Link to post Share on other sites More sharing options...
jdlaing Posted October 2, 2018 Share #4 Posted October 2, 2018 No. Link to post Share on other sites More sharing options...
zeitz Posted October 3, 2018 Author Share #5 Posted October 3, 2018 Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! I think I've attached an image from the April 2007 Mark Norton posting which shows the disassembly of an M8. The battery is in the upper left corner. I'd sure like some explanation as to why this battery never needs replacing. Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! I think I've attached an image from the April 2007 Mark Norton posting which shows the disassembly of an M8. The battery is in the upper left corner. I'd sure like some explanation as to why this battery never needs replacing. ' data-webShareUrl='https://www.l-camera-forum.com/topic/290087-m8-built-in-back-up-battery/?do=findComment&comment=3605535'>More sharing options...
jdlaing Posted October 3, 2018 Share #6 Posted October 3, 2018 What did Leica say when you asked them? Link to post Share on other sites More sharing options...
Rune Posted October 3, 2018 Share #7 Posted October 3, 2018 Advertisement (gone after registration) I unfortunately left for a small vacation in Liege, Belgium this spring with only my M8.2 (my M9-P was still at Leica in Germany for a sensor swap, and didn’t return in time…), and discovered that my backup battery was flat. I concluded with this after long time search on the Internet. I always use my M8.2 with both RAW and Large Jpeg selected, and theme set to Black & White… I like to see a B&W preview on the display… I feel more like taking B&W pictures that way… ;-P Unfortunately, all the settings, including time & date had reset it selves several times prior to my trip, but I forgot to check this during my trip… so all settings, without my knowledge, was reset to factory default, and all my pictures from the trip was taken in “S” (Large Jpeg) mode… I was furious, sad, devastated, etc returning home, and started to search… The M8.2 does indeed have an internal rechargeable backup battery, storing time, date, your settings etc… …and it can go flat if the camera isn’t used for a long time, i.e. if the normal battery is removed. In my case, I left my dear M8.2 without battery and the necessary care and attention for a long period because I used my batteries in my M9-P, and in my experience, that is the source of the trouble… The solution that worked for me, is the following: 1) (Important!) Set “Auto Power Off” to Off, leave the camera ON without the normal battery, and let the backup battery completely drain out for 14 days. 2) After that, insert a good, healthy, fully loaded normal battery in the camera, leave the “Auto Power Off” to Off..! leave the camera ON, and let the camera drain itself empty… then the backup battery will have fully recharged itself, and the camera memory will no longer be demented… It worked beautifully for me… reminder to all of us… the M8(.2)’s are begging for some use and fresh air from time to time… ;-P Best regards, Rune 3 Link to post Share on other sites More sharing options...
zeitz Posted October 4, 2018 Author Share #8 Posted October 4, 2018 Rune, thanks for the very useful information. It is interesting that the owners manual says to remove the main battery when the camera is being stored. I have never removed the battery for storage. Ask Leica? JD, we are in the US. We have nothing that even approaches customer service from Leica in New Jersey. I'd rather reset all the presets and time whenever I turn the camera on than send the camera to Leica New Jersey because they are likely to un-fix a working camera. I'm still curious as to why you said "no" to my question. And now I'm even more curious as to what battery Leica used. Link to post Share on other sites More sharing options...
jdlaing Posted October 4, 2018 Share #9 Posted October 4, 2018 They used a good one. Link to post Share on other sites More sharing options...
Kmaansson Posted May 18 Share #10 Posted May 18 I encountered the same problem with my newly acquired M8. The time is frozen in the body, for as many minutes/hours the body is without a battery inside. I tried your method @Rune and am having a hard time charging the backup battery, with or without the camera being on… I have drained 3 batteries during 3 nights.. Still it cannot keep the time, even for a few minutes. I did not do step 1 however.. It seems pretty drained already. Is the back-up battery dead? Link to post Share on other sites More sharing options...
