farnz Posted July 14, 2007 Share #1 Posted July 14, 2007 Advertisement (gone after registration) Upfront apologies if this is a daft question but clearly the M mount has 4 cams so could someone kindly tell me which Leica mounts use 3 cams please? Pete. Link to post Share on other sites More sharing options...
Advertisement Posted July 14, 2007 Posted July 14, 2007 Hi farnz, Take a look here 3 cam question. I'm sure you'll find what you were looking for!
karlitos Posted July 14, 2007 Share #2 Posted July 14, 2007 A 3 cam reference relates to R system lenses. Followed by 3rd cam only and then with ROM contact FWIW. Karlitos. Link to post Share on other sites More sharing options...
earleygallery Posted July 14, 2007 Share #3 Posted July 14, 2007 Pete, CAMS means the cams or lugs around the lens which engage with the appropriate links within the R camera body for aperture control/AE setting. I think you're looking at the lens mount itself. There are only the LTM, M, R and now 4/3 Leica mounts. Link to post Share on other sites More sharing options...
farnz Posted July 14, 2007 Author Share #4 Posted July 14, 2007 Thanks, James and Karlitos. So does this mean that 3 cam lenses are only compatible with R bodies? And is the reverse true, ie any R bodies will take any 3 cam lens? Pete. Link to post Share on other sites More sharing options...
telyt Posted July 14, 2007 Share #5 Posted July 14, 2007 Thanks, James and Karlitos. So does this mean that 3 cam lenses are only compatible with R bodies? And is the reverse true, ie any R bodies will take any 3 cam lens? Pete. 3-cam lenses are only compatible with Leica's reflex bodies unless you get an R-to-M adapter and are satisfied with guess focus. There are some incompatabilities between a few of the 3-cam variations and a few bodies. The R bodies, i.e., R3 through R9, can use any 3-cam, 3rd-cam or ROM lens. It's the Leicaflexes i.e. Leicaflex Standard, Leicaflex SL, and Leicaflex SL2 that will have problems with a few 3-cam lenses. Link to post Share on other sites More sharing options...
farnz Posted July 15, 2007 Author Share #6 Posted July 15, 2007 Thanks very much, Doug. Link to post Share on other sites More sharing options...
