20 hours ago, Greenhilltony said:
I examined the lens closely and thought I figured it out. There is a round shade behind the aperture blades. When you look through the lens from behind, and turn the aperture from 1.4 to 1.7, you won’t see the blades, because they are still block by the shade. So, the actual light transmission diameter is limited by this shade.
What you are describing is mechanical vignetting. That's why the corners of your images are darker than the center when you are shooting wide-open. In a way, you are correct that it's a 1.7 or 2.0 lens, but only for the corners. It's 1.4 in the central area.
x
M10-D, 35mm Summilux v2 @ f/1.4
Shot at f/2, my favorite setting for this lens. The bench in the background is actually skewed; it’s not the lens! 😉
M10, 35mm Summilux v2 @ f/2
  • Haha 1
V2, wide open, 1/4s hand held, Ektachrome 100 +2 stops
  • Haha 1
V2, Ektachrome 100 + 2 stops
V2, M9-P
A couple of family snapshots of my ladies at the seaside, I don’t tend to share these sort of shots but I just love the rendering on film with this lens. Fomapan 100
Soho nights.
M10-D, 35mm Summilux v2 @ f/1.4 or f/1.7
Jimmy.  M7 + 35 lux v2 + 250D
M10 + Summilux M 35mm 1,4 Vers II
Vernissage "70 Jahre Leica M"  5. 11. 2024
Claus
Claus
M10 + Summilux M 35mm Vers II
Claus
  • Like 12
Claus
M7 + v2 + 250D
  • Like 13
F11 i think. A rarity.
Wall photos from The Garden by Sian Davey
Nightwalk in Montreaux,
I think i used f1.8 on Ilford HP5 pushed to 800
  • Like 13
V2, wide open, Ektachrome 100 +2 stops
