jmahto Posted August 10, 2018 Share #1 Posted August 10, 2018 (edited) Advertisement (gone after registration) After couple of months of using manual film cameras (Konica autoreflex T2, Nikon FM2 and Leica M2), I find M2’s shutter speed dial rotation direction intuitive. Once I set A and T, the other combinations for same EV requires moving both A and T in the same direction by equal amount. To me this is more intuitive than moving them in opposite direction to keep same EV. The other camera’s (and my M240) dial turns in opposite direction but they have meter and I adjust exposure while looking through VF. Probably that’s why the shutterspeed direction doesn’t bother me much for them (M240 even tells me which way to go by LED arrows). I mean I am not looking at both A and T from the top while adjusting exposure (for M2 I look at the dials from the top). However it is a pain to go against muscle memory while switching between cameras. I do see that at some point Leica changed the direction. Am I only one who thinks older direction is intuitive! Edited August 10, 2018 by jmahto Link to post Share on other sites More sharing options...
Advertisement Posted August 10, 2018 Posted August 10, 2018 Hi jmahto, Take a look here Leica M2’s shutter speed dial rotation direction more intuitive. I'm sure you'll find what you were looking for!
spydrxx Posted August 10, 2018 Share #2 Posted August 10, 2018 I think it is whatever you get used to, not truly intuitive. 1 Link to post Share on other sites More sharing options...
Narsuitus Posted August 10, 2018 Share #3 Posted August 10, 2018 I do not care which direction they turn as long as there is consistency between cameras. Link to post Share on other sites More sharing options...
Ko.Fe. Posted August 10, 2018 Share #4 Posted August 10, 2018 Did they change rotation only in M6 TTL ? I had M3, M4-P and M4-2 now. All are the same. I could set any shutter speed without looking on the disk. It helps then I can't see dials in the dark. Then it is with metering camera, it all doesn't mater Link to post Share on other sites More sharing options...
jmahto Posted August 10, 2018 Author Share #5 Posted August 10, 2018 I do not care which direction they turn as long as there is consistency between cameras. Yes. Consistency would have been nice but digital M and M2/M3 are opposite (possibly till much later). Maybe they changed later to align with under/over exposing LED direction in the VF (so that both A and T move in same direction for similar effect of exposure). Some may find that intuitive. Link to post Share on other sites More sharing options...
jmahto Posted August 10, 2018 Author Share #6 Posted August 10, 2018 I think it is whatever you get used to, not truly intuitive.But when you have two cameras (digital M and M2/M3) that go opposite then what do you get used to! Link to post Share on other sites More sharing options...
250swb Posted August 10, 2018 Share #7 Posted August 10, 2018 Advertisement (gone after registration) Did they change rotation only in M6 TTL ? Yes they did. When I got my M6TTL at first it seemed a bit odd but the novelty only lasted a week before I could use it just as intuitively as any other body. Maybe just the feel of the larger dial flicked the switch in my head, but I could use the TTL or older body alongside each other. It's how frequently you use the camera, that's all, no magic. Link to post Share on other sites More sharing options...
Ko.Fe. Posted August 10, 2018 Share #8 Posted August 10, 2018 Yes they did. When I got my M6TTL at first it seemed a bit odd but the novelty only lasted a week before I could use it just as intuitively as any other body. Maybe just the feel of the larger dial flicked the switch in my head, but I could use the TTL or older body alongside each other. It's how frequently you use the camera, that's all, no magic. Exactly. I have no issues with M4-2 and M-E. I could have them on me by same time and no dial disk issues. Link to post Share on other sites More sharing options...
spydrxx Posted August 11, 2018 Share #9 Posted August 11, 2018 (edited) But when you have two cameras (digital M and M2/M3) that go opposite then what do you get used to! I still have 17 operational cameras, so I program myself to get used to the one I'm using at the time. Edited August 11, 2018 by spydrxx Link to post Share on other sites More sharing options...
Lukas F. Posted August 11, 2018 Share #10 Posted August 11, 2018 For both directions of rotation one can make up an explanation that sounds sensible and works for one; even if the speed dial turns in the wrong direction, like on the M2. Link to post Share on other sites More sharing options...
