MarkP Posted May 27, 2018 Share #1 Posted May 27, 2018 Advertisement (gone after registration) So my epson V700 Pro has just died. The top lid lamp no longer works. I could repair it but it is now a few generations behind the current Epson scanners. Does anyone have experience with the V800 or V850 Pros, or any alternative suggestions? I have a Coolscan 5000 but I often need a flatbed scanner, including for MF film. Mark Link to post Share on other sites More sharing options...
Advertisement Posted May 27, 2018 Posted May 27, 2018 Hi MarkP, Take a look here Replacement scanner for dead V700 Epson?. I'm sure you'll find what you were looking for!
EoinC Posted May 30, 2018 Share #2 Posted May 30, 2018 I have a V800, Mark. It works fine. I don't think there's much difference from the V700. I also have a Plustek 120, which does a might fine job on 135 / 120. 1 Link to post Share on other sites More sharing options...
MarkP Posted May 30, 2018 Author Share #3 Posted May 30, 2018 Do you think there's much difference between the Plustek and epson output? 1 Link to post Share on other sites More sharing options...
gbealnz Posted May 30, 2018 Share #4 Posted May 30, 2018 I'm using an old Epson 4870, so am envious of even your clapped out V700. I'd be fixing it to be honest. Like Eoin, I have Plustek too, but again older, smaller, it's an 8100. Like most, Epson for M/F and Plustek for 35mm, although I do "proof" my entire 35mm roll with the flatbed. The newer models I understand have LED, so don't make you wait while the "lamp warms up" Once mine dies, I'm in upgrade mode as well. Logic would suggest the later models, V800/850 are "better", but if the repair on your V700 is not excessive, it's what I'd be doing. Gary 2 Link to post Share on other sites More sharing options...
MarkP Posted May 31, 2018 Author Share #5 Posted May 31, 2018 I'll get a quote. Thanks for the advice Gary. 1 Link to post Share on other sites More sharing options...
