S-T-P Posted May 25, 2018 Share #21 Posted May 25, 2018 Advertisement (gone after registration) To my knowledge the vertical alignment of the M10 and M(240) can be adjusted with a 2mm hex key. A good quality key is available below 5 Euro, preferably from a professional tool shop. Does that knowledge improve your life? Wish you success! And for the horizontal correction: use the infinity setting first and then check close-up. I never use the ruler test, close-up is usually well corrected while the infinity setting tends to need correction once in a while. Mine as slightly off and after reading this thread I adjusted it. Very easy to do, thanks Photograph of what's under the Leica badge/Screw Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! 1 Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/284631-rangefinder-alignment-question/?do=findComment&comment=3524943'>More sharing options...
Advertisement Posted May 25, 2018 Posted May 25, 2018 Hi S-T-P, Take a look here rangefinder alignment question. I'm sure you'll find what you were looking for!
