ktmrider2 Posted April 3, 2018 Share #1 Posted April 3, 2018 Advertisement (gone after registration) I am wondering if purchasing either the 1.25 or 1.4 Leica viewfinder magnifier is worth it. It would be used mainly on the MP240 with fast 50mm lenses. I want to be able to see the entire 50 frame line and I do not wear glasses. I have never used one of these Leica accessories and would like opinions. Thanks. Link to post Share on other sites More sharing options...
Advertisement Posted April 3, 2018 Posted April 3, 2018 Hi ktmrider2, Take a look here Viewfinder Magnifiers-Worth It? . I'm sure you'll find what you were looking for!
feelssadman Posted April 3, 2018 Share #2 Posted April 3, 2018 Expensive but worth it. According to the reviews you can find online at least. 1 Link to post Share on other sites More sharing options...
LocalHero1953 Posted April 3, 2018 Share #3 Posted April 3, 2018 (edited) I got the x1.4 (for the Apo-Summicron 90) but after a while I ended up not using it. It magnifies the view, but at the cost of a bit of clarity/contrast. In the end I decided the two balanced each other out. Edited April 3, 2018 by LocalHero1953 Link to post Share on other sites More sharing options...
Photon42 Posted April 3, 2018 Share #4 Posted April 3, 2018 I used the 1.25 on the M9 for the 90 and sometimes for the 50. It comes with a reduction in brightness. Don’t feel the need anymore. Link to post Share on other sites More sharing options...
pico Posted April 3, 2018 Share #5 Posted April 3, 2018 When I really needed the magnifier it was in low light, but the diminished brightness was discouraging. Our eye/brains are different. Best if you can try one, then judge. Best of luck to you. Link to post Share on other sites More sharing options...
Richardgb Posted April 3, 2018 Share #6 Posted April 3, 2018 I got the x1.4 (for the Apo-Summicron 90) but after a while I ended up not using it. It magnifies the view, but at the cost of a bit of clarity/contrast. In the end I decided the two balanced each other out. Generally the same - I use the 1.4x, mainly for the 75/2 Summicron and occasionally for the 50/2 (the framelines are still visible). It makes the image larger but doesn't necessarily make focusing quicker - the rangefinder discrepancy from the slight twitch of the fingers when turning the focussing ring gets bigger, too - and focus on the 75/2 (well documented by other users in other threads) can still be tricky to 'nail'. Hassles? Screwing it onto the viewfinder when in a hurry - one more thing to do when changing lenses, and (along with the viewfinder optics), it's another pair of glass surfaces to keep clean. Doing so makes a big difference to ease of focusing. Link to post Share on other sites More sharing options...
ktmrider2 Posted April 11, 2018 Author Share #7 Posted April 11, 2018 Advertisement (gone after registration) Well, I found a used one at ClassicConnections and have decided to give it a try. It is the 1.25 and will be used primarily for the 50f1.1. I will report back. Link to post Share on other sites More sharing options...
Jethro Posted April 11, 2018 Share #8 Posted April 11, 2018 I have the x1.4 now permanently screwed onto my M(262) and find it handy for ease of focusing. I confess that I even use it with a 28mm and for that make a quick switch after focusing to an external OVF on the hotshoe to get the composition I want. My eyesight is 20:20 but I do really like the benefit of a slight increased rangefinder focus patch. Link to post Share on other sites More sharing options...
sblutter Posted April 13, 2018 Share #9 Posted April 13, 2018 I've tried them all - but being a bit nearsighted I have better results with just my specs. If I'm not sure of focus like in dark scenes I'll shoot several exposures and pic the best later - no reason to save chip space on a 64GB chip Link to post Share on other sites More sharing options...
ktmrider2 Posted April 16, 2018 Author Share #10 Posted April 16, 2018 Well, I got a used 1.25X magnifier from ClassicConnections and it works and works well. I would never have guessed 1.25X makes such a difference. It sure makes focusing a 50f1.1 much more precise. So, I am thinking money well spent. And just for information with a little bit of searching, you can see the frame lines for the 35mm. Thanks for the opinions. 1 Link to post Share on other sites More sharing options...
marchyman Posted April 17, 2018 Share #11 Posted April 17, 2018 I wanted to see if a magnifier was something I was interested in buying and if so, which one. A visit to the Leica Store in SF didn't answer my question -- they were out of stock! I'll check again the next time I'm in that area of the city. If nothing else I saved some money. I was within a couple blocks of the store for other reasons so I wasn't even out much time. Link to post Share on other sites More sharing options...
ktmrider2 Posted April 17, 2018 Author Share #12 Posted April 17, 2018 Classic Connection has a mint one for $280 or so (1.25X). I think that is $100 savings from new. Link to post Share on other sites More sharing options...
AndrewDD Posted April 19, 2018 Share #13 Posted April 19, 2018 I have a 1.25 permanently attached, along with a +2 dioptre. It can be a bit faint in low light, but mostly it makes focusing a lot easier. I also use it with my 35mm lens - the frame lines are right on the edge of the viewfinder. Link to post Share on other sites More sharing options...
mikeamosau Posted April 23, 2018 Share #14 Posted April 23, 2018 I just picked up a 1.25x magnifier and have been very impressed at how much it has improved my hit rate with the 50mm Noctilux f/1.0. I tried the 1.4x in the store and didn’t like how it cut off the shitter speed readout in the viewfinder. I’m very happy with it and would highly recommend it. Mike 1 Link to post Share on other sites More sharing options...
