Mike_HNL Posted March 13, 2018 Share #1 Posted March 13, 2018 Advertisement (gone after registration) On my Canon EOS 6D, I'm able to adjust exposure compensation then set exposure bracketing based on the exposure compensation adjustment. Is that possible on the Q? I have not figured whether this can be done on my Q. Sent from my iPhone using Tapatalk Link to post Share on other sites More sharing options...
Advertisement Posted March 13, 2018 Posted March 13, 2018 Hi Mike_HNL, Take a look here Exposure Compensation/Bracketing Coordination . I'm sure you'll find what you were looking for!
uffehagen Posted March 13, 2018 Share #2 Posted March 13, 2018 On my Canon EOS 6D, I'm able to adjust exposure compensation then set exposure bracketing based on the exposure compensation adjustment. Is that possible on the Q? I have not figured whether this can be done on my Q. Sent from my iPhone using Tapatalk You can set manual exposure under/over and combine that with bracketing 1 Link to post Share on other sites More sharing options...
SonomaBear Posted March 13, 2018 Share #3 Posted March 13, 2018 You can set manual exposure under/over and combine that with bracketing I usually shoot aperture priority and use ExpComp all the time. The n b racketed images come up in post, I see my original compensated image plus ones with the shutter speed varied plus/minus 1 Link to post Share on other sites More sharing options...
Mike_HNL Posted March 13, 2018 Author Share #4 Posted March 13, 2018 You can set manual exposure under/over and combine that with bracketing Thanks. Sounds like a decent workaround Sent from my iPhone using Tapatalk Link to post Share on other sites More sharing options...
Mike_HNL Posted March 13, 2018 Author Share #5 Posted March 13, 2018 I usually shoot aperture priority and use ExpComp all the time. The n b racketed images come up in post, I see my original compensated image plus ones with the shutter speed varied plus/minusThanks. This is what I want to accomplish. I'll give it a try. I'd like to see Leica emulate the Canon design that displays the adjusted exposure compensation as the starting point for the setting the bracketing. Probably a pipedream, but would like to see this in a future software release (fingers crossed). Sent from my iPhone using Tapatalk Link to post Share on other sites More sharing options...
Leica Guy Posted March 14, 2018 Share #6 Posted March 14, 2018 FYI. If you have exposure bracketing selected the flash function will be grey’d out. You didn’t ask about that, but I’ve run into this multiple times when I try and use a SF-40 and it does not work. Once you eliminate selecting bracketing, the flash works fine. Link to post Share on other sites More sharing options...
