Dear all,
do you know if the Leica R-Adapter-M works in combination with the M-Adapter-L on a CL?
Any experience ?
Thank you for your help
Didier
It works nicely. Leica CL with Summicron-R 90 mm, M to R and L to M adaptors stacked.
Edited by EUSe
I use it as well. It has the advantage of triggering the use of the righthand wheel for the magnifying focus aid, which a passive LET-LER adapter will not do. The Leica L-R adapter will  do so and will also transmit the R ROM data, but it is prohhibitively expensive.
I use both the venerable Leicina adapter (modified to take all typs of R lenses) and the Novoflex LEM-LER. Both work just fine with all R lenses.
As a side note, this is due to the APS-C crop of the CL. The Leicina adapter will vignette on full frame with some longer R lenses.
Using a two-adapter solution has another important advantage: it positions the M in the heart of Leica's camera systems.
It will take TL and SL lenses natively.
It will take M mount lenses seamlessly by the TL-M adapter.
It will, by adding the LEM-LER adapter, take all R-mount lenses.
It will take, as a bonus, by other M-whatever adapters, thousands of manual lenses of all brands.
It put an end to the cumbersome EVF solutions of M and T.
It shares a battery and charger with the Q.
Has anybody tried using S lenses on the CL  by the L-S adapter?
Doesn't work, only on the SL.
Please also note that the S-adapter-L works on the SL but you cannot stack it with other S-adapters, eg. you cannot shoot Contax 645 lenses on the SL.
Also, the SL does not support the central shutter function of Leica S CS version lenses.
Edited by JorisV
