Roberto Watson Posted February 23, 2018 Share #1 Posted February 23, 2018 Advertisement (gone after registration) Leica M-D, how to know which firmware my camera got? I have no idea Link to post Share on other sites More sharing options...
Advertisement Posted February 23, 2018 Posted February 23, 2018 Hi Roberto Watson, Take a look here Leica M-D, how to know which firmware my camera got?. I'm sure you'll find what you were looking for!
Exodies Posted February 23, 2018 Share #2 Posted February 23, 2018 Prolly something in the EXIF. Try EXIFTool https://www.sno.phy.queensu.ca/~phil/exiftool/ Link to post Share on other sites More sharing options...
Ranchhand Posted February 24, 2018 Share #3 Posted February 24, 2018 From my experience, if you turn the M-D on and after a few minutes the frame lines disappear and camera goes to sleep only to re-awaken when the shutter button is half pushed, you have the latest update. Only one update has been made to the M-D’s firmware. Link to post Share on other sites More sharing options...
a.noctilux Posted February 24, 2018 Share #4 Posted February 24, 2018 Leica M-D, how to know which firmware my camera got? I have no idea In your place, I would upgrade to last firmware 1.0.0.5 Download the last here : http://us.leica-camera.com/Service-Support/Support/Downloads?category=&subcategory=131376&type=108942&language=all Only two firmware released for M-D (typ 262). The last change add only two lenses, see the guide how to update. The first release is more important, as not to discharge the battery when user forget to turn M-D off. 1 Link to post Share on other sites More sharing options...
Roberto Watson Posted February 24, 2018 Author Share #5 Posted February 24, 2018 yes I have made upgrade to other cameras and it is really scary. I bought this camera new in 2015, and I haven´t done anything to it. so what is the new feature firmware upgrade add? From my experience, if you turn the M-D on and after a few minutes the frame lines disappear and camera goes to sleep only to re-awaken when the shutter button is half pushed, you have the latest update. Only one update has been made to the M-D’s firmware. So before update how did it behave?, my M-D does the same as you say, should I try to upgrade? I wish camera didn´t went off ever, only when changing out batteries. Thank you a.noctilux, I will have this at hand thank you all! Link to post Share on other sites More sharing options...
NigelG Posted March 1, 2018 Share #6 Posted March 1, 2018 Roberto If your M-D goes to sleep properly then you (probably) don't need to do anything. The latest firmware release 1.0.0.5 only corrects some bug with using a flash (maybe you use one - I never have) and allows for reading the codes for the new Thambar and 75 Noctilux. If you intend to use either of those lenses to their best effect on the M-D then I think firmware tweaks are the least of your worries! Link to post Share on other sites More sharing options...
Roberto Watson Posted March 1, 2018 Author Share #7 Posted March 1, 2018 Advertisement (gone after registration) Roberto If your M-D goes to sleep properly then you (probably) don't need to do anything. The latest firmware release 1.0.0.5 only corrects some bug with using a flash (maybe you use one - I never have) and allows for reading the codes for the new Thambar and 75 Noctilux. If you intend to use either of those lenses to their best effect on the M-D then I think firmware tweaks are the least of your worries! No Thambar and no 75 Noctilux, ...just in my dreams Link to post Share on other sites More sharing options...
horosu Posted May 12, 2020 Share #8 Posted May 12, 2020 So, I have an M-D. Is there a possibility to switch the power save to off: the camera to be always on? I suspect this should require reinstalling the original firmware the came with the camera, but I can't find it on Leica's website. Link to post Share on other sites More sharing options...
a.noctilux Posted May 12, 2020 Share #9 Posted May 12, 2020 2 hours ago, horosu said: So, I have an M-D. Is there a possibility to switch the power save to off: the camera to be always on? I suspect this should require reinstalling the original firmware the came with the camera, but I can't find it on Leica's website. It's not possible to turn off the power saving on M-D with new firmware 1.0.0.5 . I don't know if it's possible to downgrade, I'd not try this as turning off with the main switch became my natural habit. Even when I forget to turn off, the battery life is so long that a couple of days later of leaving the M-D on did not deplete it's battery. It's safe as usual having a second charged battery. Link to post Share on other sites More sharing options...
horosu Posted May 12, 2020 Share #10 Posted May 12, 2020 Merci Arnaud! 4 hours ago, a.noctilux said: It's not possible to turn off the power saving on M-D with new firmware 1.0.0.5 . I don't know if it's possible to downgrade, I'd not try this as turning off with the main switch became my natural habit. Even when I forget to turn off, the battery life is so long that a couple of days later of leaving the M-D on did not deplete it's battery. It's safe as usual having a second charged battery. Link to post Share on other sites More sharing options...
jiabin.sun Posted May 21, 2022 Share #11 Posted May 21, 2022 On 5/12/2020 at 5:45 PM, a.noctilux said: It's not possible to turn off the power saving on M-D with new firmware 1.0.0.5 . I don't know if it's possible to downgrade, I'd not try this as turning off with the main switch became my natural habit. Even when I forget to turn off, the battery life is so long that a couple of days later of leaving the M-D on did not deplete it's battery. It's safe as usual having a second charged battery. My biggest frustration with using md is that it stays on until the battery runs out. How did you make him stand by. . . Looking forward to your reply。 Link to post Share on other sites More sharing options...
a.noctilux Posted May 21, 2022 Share #12 Posted May 21, 2022 (edited) 22 minutes ago, jiabin.sun said: My biggest frustration with using md is that it stays on until the battery runs out. How did you make him stand by. . . Looking forward to your reply。 Check which version of your M-D firmware, copying a file in a computer. I think the first original firmware behavior is "never sleep" correction in later firmware. Just set to off when you don't use by now. Or ask Leica ... Edited May 21, 2022 by a.noctilux Link to post Share on other sites More sharing options...
jiabin.sun Posted May 21, 2022 Share #13 Posted May 21, 2022 25 minutes ago, a.noctilux said: Check which version of your M-D firmware, copying a file in a computer. I think the first original firmware behavior is "never sleep" correction in later firmware. Just set to off when you don't use by now. Or ask Leica ... Thank you. I found that the latest version is 1.1.0.0, but version 1.0.0.4 updates the 10 minute standby function. I'll try to update it. Link to post Share on other sites More sharing options...
a.noctilux Posted June 21, 2022 Share #14 Posted June 21, 2022 On 5/21/2022 at 5:05 PM, jiabin.sun said: Thank you. I found that the latest version is 1.1.0.0, but version 1.0.0.4 updates the 10 minute standby function. I'll try to update it. @jiabin.sun Do the update to later firmware cure the "sleep" timer ? Link to post Share on other sites More sharing options...
roydonian Posted July 14, 2022 Share #15 Posted July 14, 2022 (edited) I've just downloaded 1.1.0.0 for the M-D, and the instructions contained in EN_M-D FW-UPD -Lens Profile- Release Notes.pdf - a document titled LEICA M-D (TYP 262) Firmware update - solve the OP's problem of determining what version is currently in his camera. The text reads as follows: "Find out which firmware version is currently installed Select Camera Information in the main menu The current firmware version is displayed next to the menu item Camera Firmware" The German word that comes to mind is "schlamperie". Edited July 14, 2022 by roydonian 1 1 Link to post Share on other sites More sharing options...
NigelG Posted July 14, 2022 Share #16 Posted July 14, 2022 13 minutes ago, roydonian said: schlamperie English translation “Doh!” Link to post Share on other sites More sharing options...
fotomas Posted July 15, 2022 Share #17 Posted July 15, 2022 vor 13 Stunden schrieb roydonian: The German word that comes to mind is "schlamperie". Should be "Schlamperei". English sloppiness. Unfortunately it is not possible to downgrade the firmware by yourself, according to Leica. They can do it. Have had this done for my M 240 there. Link to post Share on other sites More sharing options...
roydonian Posted July 16, 2022 Share #18 Posted July 16, 2022 Scottish sloppiness, please - Scottish sloppiness. But my near 80 year old fingers and eyesight often cause minor 'typos' in what I write. However despite its age, my brain is still capable of remembering that my M9-P has a rear screen, but my M-D does not. So I'm doing better than the anonymous author of the firmware instruction document that I cited earlier. In response to the OP's original question, the free Irfanview graphics software can show the firmware standard of the M-D, but you may need to install one of its addon packages in order to be able to open DNG files. Importing a DNG file created by the M-D, then selecting Image > Information > Exif information, will show the firmware standard as a line item 'Software'. Link to post Share on other sites More sharing options...
fotomas Posted July 17, 2022 Share #19 Posted July 17, 2022 I would say you nailed it quite well with the term Schlamperei. But then it should be called a german one in this case. Never had an M-D, but I hope they will work similar to my M (240), apart from the missing screen. At least with my files I can see the firmware version in various softwares that can display EXIF data. In CaptureOne you can see it in the file info section: Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! If you have a Mac it is also shown e.g. in Preview: Guess this would work also in other software. Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! If you have a Mac it is also shown e.g. in Preview: Guess this would work also in other software. ' data-webShareUrl='https://www.l-camera-forum.com/topic/282128-leica-m-d-how-to-know-which-firmware-my-camera-got/?do=findComment&comment=4472234'>More sharing options...
