smitty's Posted February 22, 2018 Share #1 Posted February 22, 2018 (edited) Advertisement (gone after registration) Hi Folks, Been searching through the forums but have been unable to find a direct answer to this question: What is the expected life span of a M9,M8 battery? My batteries are still working but I dont feel as though they last as long as they once did without recharging. Sometimes a battery in the camera will show a good amount of charge then suddenly go down hill. M8 bought used in 2010 still working on same batteries and M9 also bought used. Without swapping out batteries in the field I would be dead in the water fairly quickly. Thanks, Smitty Edited February 22, 2018 by smitty's Link to post Share on other sites More sharing options...
Advertisement Posted February 22, 2018 Posted February 22, 2018 Hi smitty's, Take a look here Battery Life Span. I'm sure you'll find what you were looking for!
jdlaing Posted February 22, 2018 Share #2 Posted February 22, 2018 There is really no way to tell. It would depend on how many recharge cycles it has had, storage conditions, clean versus dirty power, etc. I’ve heard of them going bad in a year to lasting over 6 years. A lot of variables. Link to post Share on other sites More sharing options...
Ko.Fe. Posted February 22, 2018 Share #3 Posted February 22, 2018 My official Leica M-E battery was made in China (2015). I have no expectations due to this at all. If it will works five years, I'll be thankful. My not MiC, nor Leica batteries in cameras purchased in 2009,2010 still sufficient enough. Not as good as new, but nothing short. Link to post Share on other sites More sharing options...
olgierdc Posted February 22, 2018 Share #4 Posted February 22, 2018 After 5 years, the battery capacity has dropped to 75% (about 15k photos). Knowing that the minimum battery level for operation of the camera is 10%, the actual capacity is no more than 65% of the declared capacity. I have the impression that at lower temperatures the battery performance is even lower. Link to post Share on other sites More sharing options...
pgk Posted February 24, 2018 Share #5 Posted February 24, 2018 Like yourself I have a mix of batteries from 10 to 4 years old - all still work ok and I couldn't say if one was worse or better than the rest. Usually I run them until I get a low battery warning then change and charge. Work for me. When one fails (only one so far in ten years) I simply replace it - I currently have 6 or 7 batteries all from Leica. Link to post Share on other sites More sharing options...
