asalazar Posted February 22, 2018 Share #1 Posted February 22, 2018 Advertisement (gone after registration) Hola a todos. Soy nuevo en el foro Tengo una M6TTL y un Elmarit 24mm con un visor externo. La composición con este lente es muy difícil porque la M6TTL es un par de milímetros más alta que otras Leica M analógicas (M2,M3,M4,M5,M6) por lo que el visor externo no es muy preciso. Me encanta el lente pero quisiera buscar una Leica M que me de menos problemas Quisiera conocer si alguien tiene experiencia con alguna de estas cámaras y un Elmarit 24mm. Me interesa conocer si han tenido problemas de composición saludos desde Ecuador, América del sur Armando Quote Link to post Share on other sites More sharing options...
Advertisement Posted February 22, 2018 Posted February 22, 2018 Hi asalazar, Take a look here elmarit 24 mm. I'm sure you'll find what you were looking for!
Guest Commander Posted February 22, 2018 Share #2 Posted February 22, 2018 (edited) Buenvenido asalazar, me problema esta no hablo espanol. Uwe Edited February 22, 2018 by Commander Quote Link to post Share on other sites More sharing options...
Ratzfatz Posted February 22, 2018 Share #3 Posted February 22, 2018 (edited) Buenvenido asalazar, me problema esta no hablo espanol. Uwe ... pero la forma como tu escribes, no está mal, comandante! Salu2 Gregor Edited February 22, 2018 by Ratzfatz Quote Link to post Share on other sites More sharing options...
X_Beliebiger Posted February 22, 2018 Share #4 Posted February 22, 2018 MP con Elmarit 24 y visto externo di Leica. Adox 20 film. Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! 6 Quote Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/282069-elmarit-24-mm/?do=findComment&comment=3466474'>More sharing options...
Guest Commander Posted February 22, 2018 Share #5 Posted February 22, 2018 (edited) ... pero la forma como tu escribes, no está mal, comandante! Salu2 Gregor Gracias, el Comandante. Edited February 22, 2018 by Commander Quote Link to post Share on other sites More sharing options...
asalazar Posted February 22, 2018 Author Share #6 Posted February 22, 2018 gracias comandante, here in english: Hello everyone. I'm new in the forum I have an M6TTL and an elmarit 24mm with external viewer. Composition With this camera is very difficult because the M6TTL is a couple of millimeters higher than other analog Leica M (M2, M3, M4, M5, M6) so the external viewer is not very accurate. I love the lens but I would like to find another Leica that has fewer problems I would like to know if anyone has experience with these cameras and the Elmarit 24mm. I'm interested to know if they have had problems of composition Greetings from Ecuador, South America Armando Quote Link to post Share on other sites More sharing options...
halo Posted February 22, 2018 Share #7 Posted February 22, 2018 Advertisement (gone after registration) Hi Armando, these few millimeters do not affect the accuracy of the finder! The optical axis of the finder and of the lens must be parallel, than there is no difference. 4mm more ore less of your photographic subject in a distance of some meters - what does it mean? Nothing! Only the so called parallaxe in close distances is growing a little bit. Quote Link to post Share on other sites More sharing options...
asalazar Posted February 22, 2018 Author Share #8 Posted February 22, 2018 Thanks for the answers. Here, two pictures made at less than 1m of distance. I did not want to cut my children heads!! Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Quote Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/282069-elmarit-24-mm/?do=findComment&comment=3466761'>More sharing options...
halo Posted February 22, 2018 Share #9 Posted February 22, 2018 Nice Guys ;-)) Does your finder not have a dottet line in the upper part of the viewing area? This is a hint, which parts of the picture will fall off when you are in the near focus range. In former times everything was better ;-)))): look at this old vario finder, which has a lever underneath the eyepiece (it stands between infinity and 4m). With this lever you could tilt the finder in order to get the right picture depending on the distance of your subject. But: can you imagine, how often people did forget to adjust this lever? Or forgot it willingly because by time they got the experience to know how much will fall off in closer distances. That is my advice to you too: get experienced and dont "believe" your finder in every aspect. Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! 1 Quote Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/282069-elmarit-24-mm/?do=findComment&comment=3466842'>More sharing options...
