  • 10 months later...
I'm sure DAG could code a non Leica lens, but it depends where the flange mounting screws are and if they coincide with the coding sensor on the body, this you could check for yourself. If they do coincide it can't be coded. All bar very early Zeiss ZM lenses for example avoid mounting screws in the sensor section of the flange (and also have a rebate machined in specifically for self coding the lens).
  • 3 months later...
On 2/10/2018 at 11:19 PM, Narsuitus said:
When I enquired about having my Zeiss 35mm f/1.4 ZM 6-bit coded, Dan Tamarkin at Tamarkin Leica, 300 West Superior Street, Suite 202, Chicago, Illinois, 60654 (Tamarkin.com ) (312-642-2255) told me that they could do it.
Which Leica lens did you choose to code the Distagon?
11 hours ago, rramesh said:
I got some adapters from the same seller and I confirm they work fine. I replaced the flange on my 90mm Elmarit and 50mm Sonnar and both work as expected, no misalignment etc.
However, if your lens is not listed, I recommend to contact the seller and ask before committing to purchase. They replied to me within 24/48h (can't remember now...)
  • 2 weeks later...
47 minutes ago, Malabito said:
Why will someone go through all the hassle of using one of these adapters if you are shooting raw?
Because it matters for RAW as well. When I coded my 4/18mm with a Dremel long back (now sold), it was the slickest way to get rid of the Italian flag problem on the M8.
If you consider taking five minutes of your time to fit the replacement flange a 'hassle' then I'd like to know what you'd normally do in those five minutes because it must be fantastic and I want some.
  • Haha 2
Yes, the 25mm ZM Biogon is one of those having interfering screws.
