Very compact also means not very tall, which can make it harder to shoot since the SL screen is non-tilting. As pointed out above, the tripods that fold back on themselves can be hard to pack because the head / knobs get in the way of the legs.
For really compact, the little manfrotto table top tripods are better than nothing and unobtrusive.
I use the Markins Q3i ball head with a Gitzo GT1541T tripod. The Markins Q3i has the knobs spaced to fit the folded legs to keep it compact. It’s rated for 30 Kg and has worked well for me.
Sent from my iPad using Tapatalk
Edited by RoySmith
+1 for the Gitzo traveller carbon fibre tripod with the P0 head. I tend to take the head off and put it in another bag if it is going in the hold luggage. Or for normal use, I leave the tripod in its normal position (legs not reverse folded) so it is not at its shortest, but the legs are closed.
That Arca-Swiss P0 head is the best and most usable I have come across so far. I also use the RRS BSL arca-swiss L-plate which makes swapping from landscape to portrait very easy and no weight on the side of the tripod to make the head slip or tripod tilt.
I have looked at it, the cut out of the arca P0 where is 90 degree falls, the lower ring with inside black body attached a bit uneven, is it just the way it is?
the CNC machine shouldn't be uneven that what I thought, or does arca has replica model by 3 party?
I use arca monofix plate on SL, it’s very often come loose, I know that some people put loctite, but I don’t want it to glue on SL, I don’t mind the ballhead glue on the tripod...
Any tips?
Sent from my iPhone using Tapatalk
 yes ...... if possible change it for a specific full length RRS SL plate ...... plus the L bracket add-on. You will never regret it. Can be left on permanently, is unobtrusive and will never come loose, plus it's made exactly to ARCA dimensions.
Edited by thighslapper
I use an RRS carbon tripod (TQC 14, I think) on Jeff’s recommendaton, with an arca-swiss D4 head and quick release plate. The head is heavy, but really really sturdy. When travelling, I unscrew the head and put it in my bag, tripod straps to the outside. While it’s not the smallest, it’s compact enough and it does the job really well.
