jhluxton Posted November 24, 2017 Share #1 Posted November 24, 2017 Advertisement (gone after registration) In autumn 2016 I finally bought the M I had dreamed of getting for so long. By last month I had built my M lens collection up to three 28mm Elmarit, 35mm Summicron and 75mm Summarit. This basically covers the popular focal lengths I tended to use my X-Vario (bought 2014) for. Consequently the X-Vario has seen virtually no use for for 12 months I also have an original X bought shortly after release, this still sees some use when I need a small camera and I enjoy using this. When the CL was mooted I thought the CL might, like the previous film CL, have an M mount and make a useful second slightly more compact and less valuable camera to take out and a bout where and when I might not want to take the M. I am now wondering if I should consider replacing my X1 and X-Vario with with a CL with M adaptor as to all intents and purposes the CL is the successor to the original X / X-Vario but with the all important viewfinder? At present I have too many Leicas as I also have a V-Lux 3 which I use for jobs which require an extreme zoom. Replacing the X and X-Vario with a CL with M adaptor is starting to make sense. I presume using an M adaptor on a CL would be fairly straightforward? John Link to post Share on other sites More sharing options...
Advertisement Posted November 24, 2017 Posted November 24, 2017 Hi jhluxton, Take a look here Replace X1 and XVario with CL + M adaptor?. I'm sure you'll find what you were looking for!
jonoslack Posted November 24, 2017 Share #2 Posted November 24, 2017 An M adapter on the CL is great (it recognises the 6 bit code on your lenses) - If you get the 23 and the 18-56 you have completely replaced your Xs (with much faster AF and better image quality) 1 Link to post Share on other sites More sharing options...
jhluxton Posted November 26, 2017 Author Share #3 Posted November 26, 2017 An M adapter on the CL is great (it recognises the 6 bit code on your lenses) - If you get the 23 and the 18-56 you have completely replaced your Xs (with much faster AF and better image quality) Thanks I think I would just go for the 23 plus body and M adaptor. John Link to post Share on other sites More sharing options...
Irakly Shanidze Posted November 28, 2017 Share #4 Posted November 28, 2017 no question, this is a more modern solution with better image quality and usability. Link to post Share on other sites More sharing options...
