x
No thambar for me, but I love my other 90mm’s. I’m a huge fan of Leiter’s work, and though his style was surreal and often made great use of shallow depth of field, the infocus areas of his photos were incredibly sharp, not soft in the way the thambar renders.
Why are you so sue that he used a 150 ON A LEICA ? I think he did use also some other gear...
Anyway, 150 is an odd focal... Pentax had one, iirc (and Pentax was a very appreciated camera by professionals)... and I remember also that the Olympus 75/150  for OM cameras was considered as a little gem in the times when serious photographers had a sort of reluctance to trust/adopt zooms... could be another possibility related to Leiter's work.
could also be a 150mm hektor projector lens.
http://forum.mflenses.com/viewtopic.php?t=13073
There is a self portrait, captioned as being taken in the 1950s, in which he's peering into a Graflex. Various 150mm lenses were used on the Graflex, including the 150mm f/5.6 Schneider Symmar S.
But in the interview he clearly quotes 150 as a long focal.. which it isn't when. used on a Graflex (which was probably used with 6x9 or even 9x12 formats)
A lens like a 150 for large formats could be someway adapted for a Visoflex... but would be really an odd to use set, expecially in street... :huh:   (anyway..you could set the central shutter to T and use the Leica shutter... B) )
Astro Berlin made a 150mm f/2.3 Portrait lens in Leica M39 (screw) mount - came with its own Visoflex-like "Identoskop" viewing system.
http://collectiblend.com/Lenses/Astro-Berlin/150mm-f2.3-Portrait-(M39,-Identoskop).html
About halfway down on this long web page are some book/magazine/advertising page reproductions showing the AB 150mm/Identoskop mounted on a Barnack Leica.
http://www.exaklaus.de/astro.htm
Jeffo Wong on flickr has some samples with one (camera type unknown).
It may look massive (and probably is) and is mostly photographed attached to a tripod, but I - briefly - lugged around a similar-sized (1400g + camera weight) Zeiss Jena 180mm f/2.8 Sonnar adapted to Nikon mount back in the 1970s. It could be used for hand-held street or location snaps - by a young, healthy photographer! ;)
Note that the tripod socket/ring is removable.
Edit: Astro Berlin even made a 150mm f/1.8 version (Pan-Tachar). Both lenses also made in Exakta SLR mount, minus the Identoskop. And a 150 f/2.0 in Pentacon Six/PraktiSix (6x6 MF) mount.
Edited by adan
Astro Berlin made a 150mm f/2.3 Portrait lens in Leica M39 (screw) mount - came with its own Visoflex-like "Identoskop" viewing system....
Interesting finding... thanks. Astro Berlin seems to have had a good reputation in USA... it's an intriguing hipotesis the Leiter had one (not exactly a light set for street photo... but who knows... )
For a photographer working in the 1940s-50s, we have to remember that SLRs for long lenses (or any lenses), were few and far between - and still kludgy.
No quick-return mirrors (finder was blacked out until the shutter was recocked), few pentaprisms for eye-level or vertical pictures, no auto-stop-down of lenses (you either had to focus at shooting aperture - very dark, pre EVFs - or manually push a "preset" ring/button/lever to stop down just before pressing the shutter button). Plus, the earliest SLRs (Exakta (1930s, waist-level viewing), Contax S (1949, Pentaprism) and early Zenits (1952), were made in WW2 Germany or behind the Iron Curtain (Dresden, Jena, Krasnogorsk) during that era, and thus not readily available in the West.
It was not until the very late 1950s that Asahi Pentax, Zeiss (Stuttgart - Contarex), and Nikon began providing seriously competent, "modern," general purpose SLRs with something approaching the functionality we know today.
So in that era 1940-1960, if one wanted to shoot 35mm film with a lens longer than 135mm, it was perfectly normal, and made absolute sense, to just add on a reflex viewing system to your existing rangefinder camera (Visoflex, Identoskop, Nikon and Contax equivalents for their own rangefinder cameras). No less kludgy than the SLRs then available (or not-so-available). Or get and use a lens like the  Zeiss Contax 180 Olympia, with the viewing periscope built right into the lens.
And if that meant a heavy load to carry for perspective compression or subject isolation or other long/fast-lens tricks - it was simply how 35mm photography worked back then.
Looking at Leiter's work, it's clear he enjoyed "long flat perspective" (not all the time of course) - I'd guess he'd have had no problem hauling around "whatever it took" in pursuit of the images he wanted. Such as the "red umbrella" shots or "The Postmen."
https://www.google.com/search?biw=1675&bih=1251&tbm=isch&sa=1&ei=SKj2We_oB86cjwPJx6WgAQ&q=saul+leiter&oq=saul+leiter&gs_l=psy-ab.3..0l10.94727.96613.0.98571.11.11.0.0.0.0.102.904.10j1.11.0....0...1.1.64.psy-ab..0.11.902...0i67k1.0.o16uuS-4Gtg
Edited by adan
So in that era 1940-1960, if one wanted to shoot 35mm film with a lens longer than 135mm, it was perfectly normal, and made absolute sense, to just add on a reflex viewing system to your existing rangefinder camera (Visoflex, Identoskop, Nikon and Contax equivalents for their own rangefinder cameras). No less kludgy than the SLRs then available (or not-so-available). Or get and use a lens like the  Zeiss Contax 180 Olympia, with the viewing periscope built right into the lens...
... Yes, your reasoning is spot-on for those times : thinking well, a street photographer like Leiter probably preferred the 150 Pan Tachar to a "normal and light" Hektor 135 ...and not only for the (little) longer focal... it's heavy, true, but :
- f 2,3 : on a IIIc, this means to use 1/200 instead of 1/60 on a f 4,5 lens : big difference with a long focal.
- Reflex viewing : maybe rough but a SINGLE focusing/framing  instead of switching from RF to focus and external VF to frame.
after all, not by chance Leitz made all their well known "short mount" lenses for the Viso
