Leica Q digiscoping adapter, does it fit on 20-60x eyepiece?
phdc
I'm considering getting a Televid 77APO with the 20-60x eyepiece to use for digiscoping with my Leica Q.
Does anyone know if the Q digiscoping adapter fits on the older 20-60x eyepiece? The Q adapter is advertised as fitting the current model 25-50x Televid eyepiece which is 5.95cm in diameter whereas the 20-60x is only 5.3cm in diameter. That sounds like a shaky fit. However I've read that the Q adapter is slightly conical so that as you push the eyepiece deeper in it gets more snug. I've never seen/handled the adapter in person.
Has anyone else tried this?
Thanks,
Paul
www.paulhowe.com
I have the adapter and I’m starting to use it on a Swarovski 20x-60x eyepiece. It’s slightly larger diameter than my eyepiece even when tightened to the limit. I’m thinking I’ll wrap some tape or something around the eyepiece to give it a little more width. I only need about 2 mm.
The open diameter of the adapter is 58.6 mm. The closed dimension is 56.1 mm. The diameter of my Swarovski eyepiece is 54.5 mm. The actual closed dimension is a squished circle since the screw tightens on one side and deforms the circle in the process. I hope this helps. I’m happy with the quality of the adapter, but wish it fit my application a little better. I already had the spotting scope or I might have bought the Leica one.
  • 4 weeks later...
I posted this image of the moon on the main Q thread last week. It was fun taking it with my Swarovski ATS 80 spotting scope using the Q and adapter. It has a 20x-60x eyepiece. In this case I had it at 20X. I cropped it to eliminate the black barrel effect from the overall image. Pretty impressive detail in my mind given the arrangement. It speaks well of the quality of the Q sensor as well as the spotting scope resolution.
This kind of photography is not something I've ever tried but it looks very interesting.
It seems to me that there could be a basis for opening up a another sub- forum in the images section simply dedicated to this kind of thing
