please help, VC12mm, M8, no IR and deadly black sneakers
davichan
i know this has been beat to death.
I have been reading the forums for Over 6 months now, and still not sure of the latest fix.
i am doing a commercial shoot tommrow, all daylight, outside, in color, and using the M8 with VC 12mm without IR filter....
could not get the IR filter atachment in time...
the talent will be wearing BLACK (m8agenta) sneakers....
it is for a sneaker ad. HA (i am a sadist)
i will be shooting several pictures to hand over to client, i can say close to over 100.
i am super proficent in Photoshop, and use Lightroom now for all my digital file managment.
can some one please just clue me in on the best cure for this mess i know i will have to deal with.
thank you gang...
x
Guest licht
a. deliver black & white pictures to the client
or
b. rent a camera without those problems
or
c. use a lens with ir-filter
thank you gang...
You are brave indeed. Do you have to shoot it with the M8? If so, I'd recommend Jamie Robert's profiles. Otherwise, as much as I love the M8, I'd shoot it with something else since the client needs color. This is the kind of shoot where filters would be a real advantage.
Cheers,
Sean
best results for this is to select the offending magenta color (using the Magic Wand or Select/Color Range option), feather to taste, make a new layer as copy, desaturate and then use Color Burn with a pleasing adjustment of opacity slider (about 20 to 30 % for most cases) and then flatten
takes all of a few minutes
good luck
Wow...
I have to agree with the suggestions to use another camera. I also love working with the M8, but would never risk a client's job (and consequently my own reputation) on anything I wasn't 100% confident in. In this case, I think you're flirting with disaster.
T
damn, I only have cs2 and cs3, you would think those profiles are foward compatible..
Davi,
C1 = Capture One, not Photoshop CS1. Different animals. Jamie's profiles aren't designed to work with any version of Photoshop.
Pete.
thank you gang...
for some commercial shooting, really well prepared :rolleyes: sorry, but couldnt resist...as others mentioned use some other gear, otherwise neither you or your client will be happy
Davi--
Another solution is to use "Replace color..." in CS2. (I'm sure it's there in CS3 as well, but don't have the program.)
Duplicate the layer you want to correct to avoid over-writing the original (just in case).
Choose Image >> Adjustments >> Replace color...
Using the Selection eyedropper at the top of the window that opens, click in the magenta you want to replace; adjust the 'fuzziness' slider so that the selected area covers only the area you want to replace.
Then in the bottom ("Replacement") half of the Replace Color window, either:
1) Adjust the Hue, Saturation and Lightness sliders; or
2) Click the "Result" color swatch and choose a color as usual; or
3) Do #2 and then fine-tune with #1 above.
Then click "OK."
Hope that helps. Even though it's cheating. ;)
Good luck!
--HC
Do you know that these sneakers are made of synthetic material? It's my understanding that the magenta problem only happens for synthetic black like nylon or microfiber. If they're black canvas or leather you should be ok.
No, it happens with natural materials too - much of it depends upon the dyes used.
I agree with the others here who are cautioning against using the M8 under these circumstances and wonder whether this is a wind-up? Do you really want to be photoshopping out the magenta in 100 files? It's cheap to rent a decent DSLR and 15mm lens - infinitely cheaper than the cost of your time in Photoshop.
I find it a bit surprising that a professional photographer would consider doing an important shoot with inadequate tools, nor have access to backup, like a 5D. The photoshop expertise must have come from somewhere..
In lightroom, desaturate magenta in the camera profile. The only real problem is when you have something in the scene that should have some magenta component... Then you can't do anything about it. I took picture of a play where one actor was wearing black synthetic fabric and laying on a magenta couch... I can get both magenta or both black but that's it. I assume that's what Jamie profile does in C1.
One thing to keep in mind, since we're on the topic is that IR can effect all kinds of color rendering with a variety of subject materials. The shift with many black textiles is often discussed but it's only one of a wide variety of shifts that can occur because of IR. Some (including myself at times) actually like to let the camera have its head and render as it sees fit. But there's no way I would do that when shooting color work for a client unless the client specifically wanted a very liberal and unusual kind of color interpretation.
BTW, for those who like precision in language (I can't be the only one here), Cosina licensed the Voigtlander trade name (not vice-versa) and so the company is "CV", for Cosina Voigtlander, rather than VC. Minor point, I do realize.
Cheers,
Sean
