michaelbogdan Posted August 18, 2017 Share #1 Posted August 18, 2017 Advertisement (gone after registration) Hey all! While anxiously waiting for this camera to become available, I was wonder if you can connect the TL2 directly to an iPhone or iPad using a Lightning to USB-C cable to import photos. Not sure is there is some kind of active component in the camera adapter that Apple sells, or if you'll be to import simply with this cable. Thanks in advanced! Link to post Share on other sites More sharing options...
Advertisement Posted August 18, 2017 Posted August 18, 2017 Hi michaelbogdan, Take a look here TL2 to iPad or iPhone with USB C to Lightning Cable?. I'm sure you'll find what you were looking for!
scroy Posted August 18, 2017 Share #2 Posted August 18, 2017 I just tried it - Connecting the TL2 to an iPhone7P via a USB-C to lightning cable. There is no active connection between the iPhone and TL2. Regards, Subhash Link to post Share on other sites More sharing options...
Louis Posted August 18, 2017 Share #3 Posted August 18, 2017 Michael, I recently got an IPad Pro, hoping to use it to transfer my files when traveling instead of taking a Laptop. I asked this question in Apple store and no one could help. They have an adapter for SD card that import your photos to your Apple photo folder. This was not exactely what I wanted. After some research in the internet, I finally got for about $12, an adapter for SD Card. (The one in Apple store was much more expensive) It works perfectly. You put the lightning of the adapter in the IPad and then the SD card in the adapter. This is how it creates a folder in the IPad where the photos are transferred. When I checked them on my IPad, I just saw the jpeg.! At first, I was not very happy! I connected the IPad to my PC via the USB that comes with the charger and found my IPad in my PC. I moved the photos to my computer, and I had the good surprise to see the jpeg files AND the RAW files! No, I know I can use my IPad to get my shots that I would later process in my PC! I must also add that to my surprise, the whole process is quite fast. Check also this one: https://www.apple.com/au/shop/product/MC531AM/A/apple-ipad-camera-connection-kit Link to post Share on other sites More sharing options...
Einst_Stein Posted August 19, 2017 Share #4 Posted August 19, 2017 My T was damaged after charged directly through USB from a UK power let to USB adapter. I did that because I lost my T charger. I would not take any shortcut in the future. I will take out the battery or SD to do whatever, then put it back to the camera. Link to post Share on other sites More sharing options...
STEVEcKONG Posted August 22, 2017 Share #5 Posted August 22, 2017 Well I thought the same thing, and I use that cable to connect my TL2 with my MBP every day.. sadly nothing happened when I used that cable. 从我的 iPhone 发送,使用 Tapatalk Link to post Share on other sites More sharing options...
