Perhaps I didn't explain it properly. My apology.
The adaptor doesn't rotates or move, it's the join between the lens and the adaptor.
I was using the Noctilux 50/1 when this happened. If I try to rotate the lens, the camera will prompt for the message.
I didn't really move or rotated it, it's just sometimes when I try to focus, I accidentally rotates the lens instead of the focus ring and therefore caused the movement a little bit.
I didn't experience this when I was using other lens. My 90/2.8 is not coded and didn't have this problem. However, I never really try anyway.
I've seen it before in a slightly different situation, where my leica-m lens that is a 25 years old cron 90 that is not 6-bit coded yet would pop up messages like you mention. This is related to the fact there is a screw on the lens mount, where the optical reader on the adapter tries to read the coding. Wiggling the lens in the mount by just a little, as little like a tiny fraction of a mm, may cause wrong readout. This is most likely happening to your leica-m lens when you move it a little by holding or even focussing. Different adapters optical readers respond differently with different tolerance of precision as I saw in my case by trying that cron on a few different adapters.
The problem is the alignment of the black and white coding dots on the lens flange with relation to the sensors on the adapter (or the M body).
There is some variation on the amount of 'slack' when the lens is mounted and around the point it 'clicks' into place...... with some you can over-rotate by a few degrees and it is enough to confuse the sensor on the adapter/camera.
Due to the black/white coding over 6 positions this is more of an issue with some lenses the others.
I have a number of lenses which work fine on some cameras and regularly fail to register on others ...... it's all just a product of the rather flakey system Leica adopted to identify M lenses on their digital bodies.
I doubt if you will find any 'fault' as such, but a change of adapter may solve it as no two are exactly the same..... but the problem is the coding of the 50/1.0 ...... which must have been added at some later stage as it pre-dates coding at manufacture.
Thanks.
Most of my old M lens has no 6 bit code coded. So yeah.....I was just curious why it does to one but not the other. :)
my name is Arvin and I am not a photographer. :)
Sent from my iPhone using Tapatalk
  • 7 months later...
I'm reviving an old thread, it appears, but I may have encountered a similar problem with the M adapter-L on the new CL.  My 35mm v4 f2 Summicron, coded, and working fine on M bodies auto-codes as 35mm pre-Asph Summilux f1.4.  Has anyone else encountered a situation in which the lens codes improperly, only if used iwht the adapter?  What was the fix?  Any of you SL owner own a CL, now?
Edited by norm_snyder
 The 6 bit coding on for the 35/2 and 35/1.4 is sufficiently different that the 'over-rotation' issue cannot explain it.
Perhaps one of the 6 sensors on adapter is a bit dodgy ....... but it is hard to tell where the issue lies until someone else with a coded 35/2 tries it with an adapter on the CL ...... or you try someone elses adapter......
At the moment there are too many variables to pinpoint where the problem lies ....
I have my SL, 24/90, and the Leica M-L adapter for about a month. I can mount the 24/90 just fine with just a normal twist. But, the M-L adapter requires much more force.  Is this what your experience is with the M-L adapter?
Edited by myuen888
Same here - I think this is how it is supposed to be from Leica's side. Possibly different materials used for the SL-lenses (including being water sealed) versus the Leica M-L adapter? I cannot check since I have neither with me now.
same as meerec described already but with a uncoded Summilux 75mm. Send the lens recently to Leica for coding, since then did not appear again.
When using my Voigtländer 16mm Heliar with the M-L adapter this "unknown lens" occured always, was not possible to really work with that lens. Bought then a Novoflex M-L adapter (w/o optical sensors) and no problem anymore.
cheers
thua
