Deliberate1 Posted July 29, 2017 Share #1 Posted July 29, 2017 Advertisement (gone after registration) Friends, I would appreciate any suggestions for processing jpegs. Today I shot some quick grab landscapes inspired by wonderful ephemeral, fractured light streaming through trees. Even hand-held, they came out quite well despite the 0 to 10 zone gradations. Unfortunately, it all unfolded so fast I forgot to check the file format which was set to basic jpeg because of casual family shots I took over the weekend. Knowing that this format is not as malleable as DNG files, is there a more delicate and efficient way to make adjustments with these files. My typical work flow starts in LR where I do global adjustments and then move to PS for more targeted work. Thank for any suggestions. David Link to post Share on other sites More sharing options...
Advertisement Posted July 29, 2017 Posted July 29, 2017 Hi Deliberate1, Take a look here Post processing JPEGS . I'm sure you'll find what you were looking for!
jaapv Posted July 29, 2017 Share #2 Posted July 29, 2017 Basically no different from your usual workflow, just less malleable. I would advise to make sure you are editing in 16 bits in PS -even if the original JPG is 8 bits- to mitigate posterization. Link to post Share on other sites More sharing options...
Jeff S Posted July 29, 2017 Share #3 Posted July 29, 2017 LR is nondestructive, so you can work your files as much or as little as you prefer. Of course you won't have the same latitude as DNG, but the basic LR controls and principles still apply. Virtual copies are free.... edit to your preferred rendering(s). Current LR versions have excellent global and local control capability. I find increasingly less need for PS. Jeff Link to post Share on other sites More sharing options...
albertknappmd Posted August 2, 2017 Share #4 Posted August 2, 2017 Your protocol is perfect.. LR is non-destructive and should always be done first.. Link to post Share on other sites More sharing options...
