orc999 Posted June 17, 2017 Share #1 Posted June 17, 2017 Advertisement (gone after registration) Hello I just got my m10 today and had some problems: - I went into menu (lens selection: off, auto, M, R) and I was not able to set off,auto, I was just able to get deeper into the menu but no set or back. shutter was blocked, so had to switch it off to get out of menu. -when the camera restarted it was reset, came up with language and time selection -had another freeze during operation Both happenend within 15 minutes of use. best regards Link to post Share on other sites More sharing options...
Advertisement Posted June 17, 2017 Posted June 17, 2017 Hi orc999, Take a look here M10 issues. I'm sure you'll find what you were looking for!
jaapv Posted June 17, 2017 Share #2 Posted June 17, 2017 Things that happen within the first 15 minute of use are often simple unfamiliarity with the camera; let us know how you get on. Link to post Share on other sites More sharing options...
orc999 Posted June 17, 2017 Author Share #3 Posted June 17, 2017 I got you point but they were freezes. I shot with several m10 and all leica line up already. Even if I would have not been able to set a setting, switching off the camera should not lead to a factory reset, no? Link to post Share on other sites More sharing options...
Simon Posted June 18, 2017 Share #4 Posted June 18, 2017 I've heard of the random reset issue and it also happened after first use. What's funny is these teething issues seem to settle down even without any new firmware. Hopefully you don't see it again but by all means report it to Leica if you experience any other problems. Link to post Share on other sites More sharing options...
phongph Posted June 18, 2017 Share #5 Posted June 18, 2017 I got you point but they were freezes. I shot with several m10 and all leica line up already. Even if I would have not been able to set a setting, switching off the camera should not lead to a factory reset, no? Hi!I think You change the SD card, esp. below 32 Gb. It may work. I and my friends have no problem with some M lens more than 1 month. Have a good day! Thanks! Link to post Share on other sites More sharing options...
jaapv Posted June 18, 2017 Share #6 Posted June 18, 2017 I got you point but they were freezes. I shot with several m10 and all leica line up already. Even if I would have not been able to set a setting, switching off the camera should not lead to a factory reset, no? Well, the little internal battery that feeds the permanent memory for settings etc. takes its power from the main battery. Maybe it was so drained that it took a few minutes to get functional. Link to post Share on other sites More sharing options...
pnoble Posted June 19, 2017 Share #7 Posted June 19, 2017 Advertisement (gone after registration) I have had my M10 for several months and for the first time today it froze up twice within a minute or two. Data write LED stuck on. Only way to resolve was to remove the battery. Fully charged battery, DNG + L-JPEG, 3-4 shots over 2-3 seconds (set to single shot), auto ISO, speed, WB. No LV, 1600 ISO. Sony 64GB/94 MB/s SD-XC card. Nothing unusual. Surely shouldn't fill the buffer. Link to post Share on other sites More sharing options...
ivancook Posted June 19, 2017 Share #8 Posted June 19, 2017 This happened to me once as well. Pretty sure it is an SD card issue and hopefully will be addressed in the next firmware release. Link to post Share on other sites More sharing options...
HELM Posted June 20, 2017 Share #9 Posted June 20, 2017 anyone else have an issue to image review "play" where the image does not get displayed but a black screen and just the file name? It gets exported into LR fine, but no way to see the image vie the M10 I've rebooted, reformatted the card and swapped batteries. Days later still an issue Link to post Share on other sites More sharing options...
jdlaing Posted June 20, 2017 Share #10 Posted June 20, 2017 Try a different card. Link to post Share on other sites More sharing options...
roverover Posted June 23, 2017 Share #11 Posted June 23, 2017 anyone else have an issue to image review "play" where the image does not get displayed but a black screen and just the file name? It gets exported into LR fine, but no way to see the image vie the M10 I've rebooted, reformatted the card and swapped batteries. Days later still an issue I have experienced this same issue with my M10 during a photo session i was doing a couple of weeks ago. It seemed odd when it happened and i don't recall exactly how i had the camera set up or what i was doing, i do recall having the EVF installed. When it happened, i had taken a photo and did see a black screen and file name when i looked at the LCD. I took another photo right after that and had the same thing happen again. I remember turning the camera off, restarting it and it was fine after that and has been ever since, so for me, so far, it was a 1-time glitch. If others are having this experience, i presume it may happen again, but in my 3 or 4 weeks of M10 usage, it has only happened 1 time. Link to post Share on other sites More sharing options...
