antigallican Posted July 22, 2017 Share #321 Â Posted July 22, 2017 Advertisement (gone after registration) Photomechanic? 1 Link to post Share on other sites More sharing options...
Advertisement Posted July 22, 2017 Posted July 22, 2017 Hi antigallican, Take a look here New Firmware 3.0. I'm sure you'll find what you were looking for!
FMB Posted July 23, 2017 Share #322  Posted July 23, 2017 May be you both haven't understood what in my poor and simple English have said. Can you speake Spanish?  Sorry its my best. I want that my expensive and sophisticated camera numbered my images well; not Adobe. Thank you for your already known advises and other...  Francisco Link to post Share on other sites More sharing options...
LD_50 Posted July 23, 2017 Share #323 Â Posted July 23, 2017 I understood you want the camera to continue numbering images sequentially even after firmware updates. So do I. Â I'm offering you a quick and easy solution that doesn't require you wait on Leica to fix this. Link to post Share on other sites More sharing options...
FMB Posted July 23, 2017 Share #324 Â Posted July 23, 2017 I also understood your intention is help me. Thank you. Â Francisco. Link to post Share on other sites More sharing options...
thua Posted December 31, 2017 Share #325  Posted December 31, 2017 Have a bug report to describe for the new firmware.   Overall love the new update.  Shot my first big event yesteday with the new firmware installed.  I use M-lenses (& 1, R lens) on the SL.  Two of my lenses are Zeiss, a 50mm F2 Planar and a 21mm 2.8 Biogon. For past iterations of the firmware, I could pick a similar Leica-branded lens profile for my Zeiss lenses.  When I mounted either Zeiss, the lens profile I wanted showed up on my options list immediately.  I'd have to go thru the trouble of manually going to the menu, but the lens selection was there and "it would stick" as long as the lens was mounted.  Even if I  removed a Zeiss lens and would eventually go back to it later in a shoot, the lens selection would usually hold.   NOW, I'm given 3 options when a  non-Leica lens is mounted,  OFF, Auto, and Leica-lens which brings me to a list.  I go to the list and select my close lens-profile approximation.  Then when I shoot, I get a quick warning screen telling me I've mounted an unrecognized lens.  To remove the screen, I need to half-press the shutter button, or if I'm continuously shooting, the warning screen goes away without interrupting my shooting sequence.  The images ARE captured but I don't even know if the camera is applying the leica-branded lens profile.  Somewhat irritating and must be a bug.   Still am greatly enjoying the new firmware.  Camera seems snappier for all capture related functions. never found an answer to this bug report, as I am experiencing the same issue ( Voigtlander Heliar 15 mm M-mount) where the camera is always showing "unknown lens dialogue", even when assigning the Heliar as an M-lens, even when putting auto lens detection to off... Quite annoying when taking pictures with the Heliar. Anyone knows a solution ? thx thua Link to post Share on other sites More sharing options...
thua Posted December 31, 2017 Share #326 Â Posted December 31, 2017 do not find "edit post", therefore another one: Â this frequent "unknown lens dialogue" does not appear with coded Leica M-lenses and does not appear with uncoded Leica M-lenses assigned in the dialogue. Only with non Leica lenses. Seems that the software is checking more then the 6 bit code as it proposes several Leica lenses when the 15mm Heliar is mounted. Is the software/ sensor able to check the focal length? Link to post Share on other sites More sharing options...
Alo Ako Posted December 31, 2017 Share #327 Â Posted December 31, 2017 (edited) Advertisement (gone after registration) Anyone knows a solution ? There is no solution as long as Leica doesn't support 3rd party lenses. Why should they do that? Â Â Is the software/ sensor able to check the focal length? Â No. Edited December 31, 2017 by Alo Ako Link to post Share on other sites More sharing options...
Michael Hodges Posted January 1, 2018 Share #328 Â Posted January 1, 2018 I wonder if this is a mechanical issue as I noticed a Zeiss doing this frequently during focusing ( Torqueing the mount?). Â Is there a mechanical "lens present" sensor present that can become fooled by a mount with slightly different tolerances? Â Or perhaps a reflective or bright/dark object (screw, etc.) with some 3rd party lenses that can shift slightly in the mount and trigger the coding's optical sensor to re-evaluate? Link to post Share on other sites More sharing options...
