TAAB on series 5 50/2 Summicron
wlaidlaw
Whereas I love the performance of my 1999 Special Edition LTM Series 5 50mm Summicron on my LTM cameras, I really miss not having a focus tab or even a bump on it. Apart from anything else, you don't have a tactile reference of where the lens is focussed, when you first bring the RF to your eye. I thought I would try a TAAB https://www.lenstab.com/product/taab-mini/ on the Summicron. I went for the Mini size as it would seem that it would just stretch to fit the Summicron. Well it was a struggle to get it on, needing for it to be soaked in boiling water to soften it and using a wooden skewer to lever it on. However now it is on, whereas not as good as an original tab, is a lot better than nothing. The circular strap is toothed on the inside so that it will not slip.
Wilson
Jac,
I think the TAAB is a little neater, especially when used on small LTM cameras. Having had something made by S K Grimes in the past, I bet the TAAB at $10 is a lot cheaper!
Wilson
Jac,
Wilson
Cheaper? Grimes? :)
