Leitz Elmar 1.4/135 Leitz Wetzlar spare parts.
Dave M
Hi I purchased a leitz elmar 1.4/135 leitz wetzlar lens a while back  the tripod mount and two screws are missing, this is a long shot but does anyone have the missing parts they would like to sell thanks for your help Dave.
I think the Hektor 135mm uses the same part, and I'm guessing someone took it off so it would fit in an earlier hard plastic case.
The parts are the two screws, the mount and a backing piece that goes inside.
It would be helpful if I knew the screw sizes I could probably machine the mount out of Aluminium thanks Dave.
If I were not a broke tramp I would send you the parts you need,
but you are a machinist. You can measure and make anything, from
measuring your lens including the screws.
Just how lazy are you?
For 135mm lenses there were two tripod mounts: one for only 1/4" and another later for both 1/4 and 3/8". Yes, it took Leica a while to learn that could be so. The downside is that some of the early hard plastic 135mm cases only worked with the early 1/4" mounts. So who needs those plastic cases anyway? (Some had gold trim. Rather optimistic, no?)
  • 3 months later...
