pixelstrata Posted March 22, 2017 Share #1 Posted March 22, 2017 Advertisement (gone after registration) I have a silver grey M9. It has some 'scuffs' on the top of the toplate. Not scratches. I don't really bother with them that much. Though I wonder if some minimal rubbing on the top of the top plate could replace these scuffs with the an irregular brass patina over some of the top plate. It would basically just look a bit nicer than the current black scuffs. How would something like this be done? Link to post Share on other sites More sharing options...
Advertisement Posted March 22, 2017 Posted March 22, 2017 Hi pixelstrata, Take a look here Question on brassing silver grey M9. I'm sure you'll find what you were looking for!
uhoh7 Posted March 24, 2017 Share #2 Posted March 24, 2017 The brass is very deep under chrome paint, unlike the Black M9, which does not use the chrome paint. Best to ignore the whole issue and take solace that even M6 and M10 black cameras will never do this: DSC09786 by unoh7, on Flickr For some reason I don't see much brassing on black 240s, but I don't think they use chrome paint as the M10 does. Link to post Share on other sites More sharing options...
pixelstrata Posted March 28, 2017 Author Share #3 Posted March 28, 2017 Great advice - I will just ignore it. Anyway my failing eyesight at very close distance means I don't notice much.. Link to post Share on other sites More sharing options...
jaapv Posted March 28, 2017 Share #4 Posted March 28, 2017 The brass is very deep under chrome paint, unlike the Black M9, which does not use the chrome paint. Best to ignore the whole issue and take solace that even M6 and M10 black cameras will never do this: DSC09786 by unoh7, on Flickr For some reason I don't see much brassing on black 240s, but I don't think they use chrome paint as the M10 does. Chrome paint doesn't exist. It is either paint or black chrome. Link to post Share on other sites More sharing options...
jaapv Posted March 28, 2017 Share #5 Posted March 28, 2017 I have a silver grey M9. It has some 'scuffs' on the top of the toplate. Not scratches. I don't really bother with them that much. Though I wonder if some minimal rubbing on the top of the top plate could replace these scuffs with the an irregular brass patina over some of the top plate. It would basically just look a bit nicer than the current black scuffs. How would something like this be done? This is coating AKA paint. Anything you do to it will make it look worse. Let the camera wear its battle scars with pride. Link to post Share on other sites More sharing options...
uhoh7 Posted March 29, 2017 Share #6 Posted March 29, 2017 Chrome paint doesn't exist. It is either paint or black chrome. You mean it is either Black Paint or Black Chrome or Silver Chrome. As usual, you are right, of course. Poor choice of words by me. I should have said chrome plate or chrome coating. Bill Rosauer "The reason why the cameras with brass top plates in black chrome get "silvery" on the edges instead of braising is because of the nature of the black chrome plating process. It is not a single black chrome plate, but rather a series of platings applied to the metal part. On the zinc top plates, first a flash coat of copper is applied, then nickel plating, chrome plating and then the finish black chrome plating. I believe the copper flash coat was not used on the brass top plates. Since the bright chrome plating is very durable, it is rare to wear past this on the black chrome cameras. Black paint cameras on the other hand do not have these coatings and wear through to the brass rather easily. " So M10 is brass, which is "chromed" or coated/plated with chrome which is then painted silver or black. Or is the black in the chrome? Hence Black Chrome finish? I think it's painted because the black does where off first. Which begs the question, why isn't it just stainless steel? Lighter and looks great, don't need any paint at all, or coating/plating. Or Aluminum, like M262? Link to post Share on other sites More sharing options...
TomB_tx Posted March 29, 2017 Share #7 Posted March 29, 2017 Advertisement (gone after registration) The original silver-grey M9s were just grey paint - not plated. The M9P in silver was chrome plated. The top plates are machined from brass - which machines easily. Stainless is much harder and more expensive to machine, and tooling wears faster (due to the abrasive nature of the chrome components) and so is not good for long production runs. The M60 used stainless as an experiment - so if you want stainless look for one of them! Link to post Share on other sites More sharing options...
