240: Settings change themselves?
sblutter
Recently I started a new B&W series, so went into the menu which I haven't visited in a long time - to DNG+JPG fine and film mode to B&W to get a preview.
Running through the menu I noticed a lot of settings were not right:
Metering not classic / center
Lens recognition Auto - I've had that set to Off since M9 (everything I print is from DNG anyway)
Self timer @ 12 secs (!?)
Several more also needed to be put right - I didn't make note of them all
FW:  2.0.3.0.  Battery @ 90%+
Any ideas / comments?
Not a big deal, but now I'll want to check 1st when heading out.  A nuisance - and an unfortunate loss of confidence
At least I'm being singled out!
I imagine if I can save it to the chip, can also save to computer and then install on other chips
Not bad, thanks for the tip!
I'll read more in the manual...
[...] I imagine if I can save it to the chip, can also save to computer and then install on other chips [...]
It's just a file called "Profiles.M". You will find it on your SD card after saving profile(s) through "User Profile" / "Save as Profile" in the "SET" menu. This file will be erased when formatting the card so it may be prudent to save it to an hard disk or other media.
