My SL wont recognise my 90mm APO
Guest NEIL-D-WILLIAMS
The Leica M-SL adapter doesn't have any dots, the 6 bit code is on the lens side. And if not you have to code the lens form Leica service or to select the lens manually in the SL menue
will it remember it once it's been programmed manuly
If the lens isn't coded then it's impossible for it to communicate this limited data to the camera. You have two choices:
1- get the lenses coded, either by Leica or another service provider or you can do it yourself.
2- make a manual selection when you use the lens.
Sent from my iPhone using Tapatalk Pro
It will stay assuming that you are using the same uncoded lens as you did last time if you switch to a coded lens and then switch back.  Easy to forget to change the setting if you swap between different uncoded lenses ...  :(
