01af Posted April 10, 2024 Share #21 Posted April 10, 2024 Advertisement (gone after registration) vor 26 Minuten schrieb LocalHero1953: I often crop landscape images to 16:9 [...], and portrait images to 10:8 ... So do I. Neither is 1.5:1. 1 Link to post Share on other sites More sharing options...
Advertisement Posted April 10, 2024 Posted April 10, 2024 Hi 01af, Take a look here Help Me Understand Why Photographic Paper Isn't 1:1.5 Ratio? . I'm sure you'll find what you were looking for!
Mr.Prime Posted April 18, 2024 Share #22 Posted April 18, 2024 (edited) I used to worry that cropping was a sign of bad framing / technique but now I see it as another part of the creating process. This means being free to crop to any ratio I see fit that brings out the best in the image according to my taste. I don't feel restricted in doing so. I happen to have a hybrid workflow where I no longer use wet paper but I don't think it needs to be a limitation whether wet printed or hybrid. I would make the print using paper you have that minimizes waste, but crop anyhow you see fit. For framing, you may need to make a custom border, so if you are able to cut your own borders you are good to go. And maybe you images would stand out from the crowd with a custom ratio? Of course, I am my own client, I have no paying-master or web-designer to constrain me (and no museum will be looking for my work!!!). Edited April 18, 2024 by Mr.Prime Link to post Share on other sites More sharing options...
Danner Posted April 19, 2024 Share #23 Posted April 19, 2024 A higher aspect ratio, say greater than 1.5:1, has a more modern look to my eye. Often, I split 8x10 to make two 8x5 (1.6:1) sheets, or split 11x14 to make 7x11 (1.57:1) sheets. Link to post Share on other sites More sharing options...
