Ataner Posted January 1, 2017 Share #1 Posted January 1, 2017 Advertisement (gone after registration) Hy, searched and searched - please help - but where in the menu I can select the 1 Point AF size ? Thank you Link to post Share on other sites More sharing options...
Advertisement Posted January 1, 2017 Posted January 1, 2017 Hi Ataner, Take a look here Size of 1 Point AF metering area now selectable (Small / Standard / Large) . I'm sure you'll find what you were looking for!
QKnipser Posted January 1, 2017 Share #2 Posted January 1, 2017 You need the actual firmware. Press the delete button and then you can change the size with the thumbwheel. Hans 1 Link to post Share on other sites More sharing options...
lucerne Posted January 1, 2017 Share #3 Posted January 1, 2017 (edited) You need the actual firmware. Press the delete button and then you can change the size with the thumbwheel. Hans Yes. Make sure you have downloaded and installed the latest firmware. It's version 2.0Then the instructions from QKnipser will work. This is an example of problems when not everyone has installed the firmware updates . The manual may not reflect the operation of the modified system, and if you haven't been reading forum posts between three and six months ago, you may not be aware of the firmware updates. Good luck Edited January 1, 2017 by lucerne 1 Link to post Share on other sites More sharing options...
Ataner Posted January 1, 2017 Author Share #4 Posted January 1, 2017 Yes. Make sure you have downloaded and installed the latest firmware. It's version 2.0 Then the instructions from QKnipser will work. This is an example of problems when not everyone has installed the firmware updates . The manual may not reflect the operation of the modified system, and if you haven't been reading forum posts between three and six months ago, you may not be aware of the firmware updates. Good luck Thank you - I installed the firmware version 2.0. immediately after it was published; DELETE Button - press - thank you very much - problem solved. It is really strange to me that this function is hidden in the delete-button not in menu. Greetings and happy new year from Vienna. 1 Link to post Share on other sites More sharing options...
microview Posted January 2, 2017 Share #5 Posted January 2, 2017 Thank you - I installed the firmware version 2.0. immediately after it was published; DELETE Button - press - thank you very much - problem solved. It is really strange to me that this function is hidden in the delete-button not in menu. Greetings and happy new year from Vienna. I went to v2.0 and then wondered how you could vary the magnification. Would not have dreamt of going to 'delete' button. Thanks… 1 Link to post Share on other sites More sharing options...
beez Posted January 2, 2017 Share #6 Posted January 2, 2017 Thank you - I installed the firmware version 2.0. immediately after it was published; DELETE Button - press - thank you very much - problem solved. It is really strange to me that this function is hidden in the delete-button not in menu. Greetings and happy new year from Vienna. The nice thing about not having this function in the menus, is it's much faster this way and can be changed quickly while shooting, something I do all the time. 1 Link to post Share on other sites More sharing options...
wolfbird Posted January 23, 2020 Share #7 Posted January 23, 2020 (edited) Advertisement (gone after registration) On 1/1/2017 at 9:27 AM, QKnipser said: You need the actual firmware. Press the delete button and then you can change the size with the thumbwheel. Hans Were these instructions for the Leica Q or the Q2 (To the best of my knowledge, the current Firmware for the Q2 is 1.1 vs 2.0 for the Q). So, for me, having a Q2 and pressing “delete” gives me entirely different results. Secondly, how do you find the 1 Point AF on the Q2? Thanks Edited January 23, 2020 by wolfbird Link to post Share on other sites More sharing options...
jeverett Posted January 23, 2020 Share #8 Posted January 23, 2020 The delete trick is for Q, you cannot change size of spot focus on Q2. I have requested and talked to Leica support about the lack of this function. 1 1 Link to post Share on other sites More sharing options...
