jaapv Posted May 4, 2017 Share #21 Posted May 4, 2017 Advertisement (gone after registration) Don't use Eclipse when the bottle is years old. The plastic softeners from the bottle can leave a nasty residue. 1 Link to post Share on other sites More sharing options...
Advertisement Posted May 4, 2017 Posted May 4, 2017 Hi jaapv, Take a look here Sensor Cleaning Menu...Dust Detection not Working. I'm sure you'll find what you were looking for!
rbaron Posted May 4, 2017 Share #22 Posted May 4, 2017 Don't use Eclipse when the bottle is years old. The plastic softeners from the bottle can leave a nasty residue. A good point! Link to post Share on other sites More sharing options...
ru2far2c Posted May 4, 2017 Share #23 Posted May 4, 2017 Don't use Eclipse when the bottle is years old. The plastic softeners from the bottle can leave a nasty residue. Thanks for the tip!! Wet swabbing will have to wait for a bit... Link to post Share on other sites More sharing options...
rbaron Posted May 5, 2017 Share #24 Posted May 5, 2017 Out of curiosity I just went to the manufacturer's faq (http://photosol.com/faq/) and learned: SHELF LIFEWhat is the expected shelf life of our products? E-wipe has an indefinite shelf life when kept in original package. upon opening, towelette should be moist. If not, discard. PEC-12® ; Eclipse; AEROclipse; E2 : if the fluid inside is clear, product is safe to use. If milky white – even slightly – do not use. (If you would like a source for E-2, we know of a supplier who still has some in inventory.) Sensor Swab Plus : discard PEC*PAD & ULTRA SWAB : indefinite when kept in original packaging . Link to post Share on other sites More sharing options...
sblutter Posted August 16, 2019 Share #25 Posted August 16, 2019 On 12/27/2016 at 1:33 AM, david strachan said: Thanks Exodies. Did the reset. It's solved... Seems my ltm lenses with M adapters don't work for Dust Detection. Hint was from Pop..thanks mate! I tried one of my few M mount lenses...90mm-C...and Dust Detection worked...yea! For some reason the cut-outs on the adapters signal no lens perhaps. When i get home I'll try some other adapters. But good to know it is a hardware problem...glitch. Like all of us we want "perfect working order". Thanks everyone for your help. Cheers... Link to post Share on other sites More sharing options...
sblutter Posted August 16, 2019 Share #26 Posted August 16, 2019 Dust detection became avail once I switched to a Summi from an LTM lens Glad I looked, sensor needs some care Link to post Share on other sites More sharing options...
