Guest NEIL-D-WILLIAMS Posted December 18, 2016 Share #1 Posted December 18, 2016 Advertisement (gone after registration) I have just taken my Leica SF58 out of the closet and plan to use it with both my Leica S007 and Leica SL while in the UK mainly shooting pictures of my newly born Grandson.............Ive got the user manual open right now but have a question. The manual doesn't mention SL or S007 so I am not sure if I will have to shoot in manual or does it work in TTL. I have an off camera sync cable so hopefully it will work okay. Any tips advice would be much appreciated Neil Link to post Share on other sites More sharing options...
Advertisement Posted December 18, 2016 Posted December 18, 2016 Hi Guest NEIL-D-WILLIAMS, Take a look here Leica SF58 Flash on Leica S007.......can TTL or not . I'm sure you'll find what you were looking for!
R3D-D0T Posted December 18, 2016 Share #2 Posted December 18, 2016 SF58+ S combination is a POS in TTL. You're better off doing it manually. Link to post Share on other sites More sharing options...
Guest NEIL-D-WILLIAMS Posted December 18, 2016 Share #3 Posted December 18, 2016 SF58+ S combination is a POS in TTL. You're better off doing it manually.okay I will try it I will need to google how to do that as I don't have a clue Link to post Share on other sites More sharing options...
Guest NEIL-D-WILLIAMS Posted December 18, 2016 Share #4 Posted December 18, 2016 SF58+ S combination is a POS in TTL. You're better off doing it manually.POS??? Link to post Share on other sites More sharing options...
david strachan Posted December 18, 2016 Share #5 Posted December 18, 2016 Congratulations Neil, on your new, brand new, Grandson. Maybe better than a new camera... Set on manual and bounce the light off the ceiling, or a wall...forget face-to-face flash, it's nasty. all best... Link to post Share on other sites More sharing options...
Guest NEIL-D-WILLIAMS Posted December 18, 2016 Share #6 Posted December 18, 2016 Congratulations Neil, on your new, brand new, Grandson. Maybe better than a new camera... Set on manual and bounce the light off the ceiling, or a wall...forget face-to-face flash, it's nasty. all best... Cheers DaveI will do like you say, set the flash in Manual and chimp and adjust until I get it right.......... I hope Rome has got loads of patience with grampy Williams :) :) Link to post Share on other sites More sharing options...
Guest NEIL-D-WILLIAMS Posted December 18, 2016 Share #7 Posted December 18, 2016 Advertisement (gone after registration) Dave can the SF58 HSS in manual Link to post Share on other sites More sharing options...
Jeff S Posted December 18, 2016 Share #8 Posted December 18, 2016 POS??? Piece of sh*t. Technical review terminology. Jeff Link to post Share on other sites More sharing options...
Jeff S Posted December 18, 2016 Share #9 Posted December 18, 2016 http://www.l-camera-forum.com/topic/258842-some-leica-s-flash-questions-sf20-sf58-sf64/?p=3019598 Jeff Link to post Share on other sites More sharing options...
Guest NEIL-D-WILLIAMS Posted December 18, 2016 Share #10 Posted December 18, 2016 Thanks mate. Got something to read on the plane[emoji3] Sent from my iPhone using Tapatalk Link to post Share on other sites More sharing options...
FlashGordonPhotography Posted December 18, 2016 Share #11 Posted December 18, 2016 The SF58 seems to work about the same on the 007 as on the SL. Because of the DSLR style of the camerra it has a separate meter for the flash exposure and handles bounce a touch better than a mirrorless camera. I find that switching to auto mode can help as the sensor in the flash is more predictable. HSS works fine. Gordon Link to post Share on other sites More sharing options...
albireo_double Posted December 18, 2016 Share #12 Posted December 18, 2016 A bit off topic, but the new SF-64 works much better with the S007 than the SF-58. Much shorter gap between the pre-flash and the main flash and exposures are more accurate. Fluent/automatic switching with the SF-64 between TTL and TTL-HSS depending on the shutter speed selected and the type of lens (the flash keeps in TTL until 1/1000s if you use a CS lens and then moves into TTL-HSS, whereas with an S lens it goes to TTL-HSS once you move shutter speed past 1/125s). I sold the SF-58 and got the SF-64. Happy about the newer one. Other than that, I've read somewhere that it is not advisable to shoot newborn babies with flash as it can stun them. I wouldn't do it. Link to post Share on other sites More sharing options...
albertknappmd Posted December 22, 2016 Share #13 Posted December 22, 2016 bounce while in Auto mode and adjust accordingly.. Hit or miss but that is the best one can do! Congratulations, Grandpa! Albert Link to post Share on other sites More sharing options...
FlashGordonPhotography Posted December 26, 2016 Share #14 Posted December 26, 2016 Other than that, I've read somewhere that it is not advisable to shoot newborn babies with flash as it can stun them. Stunning prior to cooking is the humane thing to do...... Gordon Link to post Share on other sites More sharing options...
