Green cast using the 21/1.4 with UV/IR Filter
TheGodParticle/Hari
Heads up to anybody using the 21/1.4 on the SL with the Leica Serie VIII UV/IR filter, im seeing green cast on all corners
I then shot without the UV/IR filter and the green cast was absent
Haven't noticed this with the 24/1.4 or 28/1.4, will shoot some samples tomorrow to verify
Anybody else encounter this? Any experiences to share?
I will order a plain UV Filter with the assumption the green cast will not be present in the shots
Not surprising, in fact I would be amazed if it were not so. You can use Flat Field Correction in postprocessing to eliminate the problem.
